Question about ViewSonic G90fb 19" CRT Monitor
"memory recall ok?" message has started appearing on the monitor frequently
I am getting frequent "memory recall" message on my monitor with 'yes' 'no' option..this was not happening before
    New Friend:
  • 113 Answers
Set the "Resolution Notice" to "OFF" in the Setup Menu of your Monitor or alternatively try installing your Monitor Drivers again using the CD which came with your monitor.
Posted on Apr 23, 2009
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
I get a message to change the resolution , but after I do that the message doesn't go and the monitor goes to sleep???
restart the computer and press f 8 and press frequently untill menu will appear then highlight enable vga mode and press enter your problem will be solved
Mar 30, 2010 | HP L1706 17" LCD Monitor
Memory Recall OK
it may be due to stuck setting button on lcd monitor or due to faulty circuit ... try to see if buttons are stuck ..nudge them a little to see if that makes a difference otherwise call the company technician.
Aug 08, 2009 | ViewSonic VA721 17" LCD Monitor
OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Dec 20, 2008 | Philips 150S4FB 15" LCD Monitor
MEMORY RECALL OK?
From the Users Manual for this monitor:
"Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting."
When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2.
If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that.
It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck.
Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife.
If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty.
One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows.
Hope that helps solve your problem...
Feb 09, 2008 | ViewSonic E70f 17" CRT Monitor
Moniter problem
Sep 16, 2007 | Computers & Internet
MEMORY RECALL OK? problem mine is view sonic monitor .from the past one month its showing problems in display.its giving "MEMORY RECALL OK?" and this whether i press any of the two buttons asked for ,is...
From the Users Manual for this monitor: "Memory Recall returns the adjustments back to factory settings if the display is operating in a factory Preset Timing Mode listed in the Specifications of this manual. - Exception: This control does not affect changes made with the User Color control, Language Select or Power Lock setting." When the monitor is asking "Memory Recall OK?" it either wants to initiate a settings Recall, or it's asking if the Recall was successful. In either case, the "Memory Recall OK?" message is supposed to go away when you push either button 1 or button 2. If it does this when you are adjusting settings then it's likely just doing what you told it to, even if you don't realize you told it to do that. It's also possible for one of the settings buttons to be stuck down and this is causing it to try and change the Recall settings. Push each of the buttons on the monitor and pay attention to what each one feels like as you push on it. If one of them feels different from the others, it's likely stuck. Tapping lightly on the settings buttons or on the panel beside them will usually free up a stuck button. If a button is stuck and won't loosen up by tapping beside it, you might need to pry up on the edges of the button VERY gently with the sharp tip of a pointy kitchen knife. If it's doing this when you did not touch any of the settings buttons at all, then this is likely being caused by a dendrite whisker or faulty circuit trace inside the monitor and you'll need to take the monitor to a service technician for repair. But remember to contact Viewsonic first and go to whatever Service Center that they advise, since a repair of this type may be covered under warranty. One other thing you could try before spending money on it is simply to change the Timing mode in the Windows display settings. Go to "Control Panel > Display", then select the "Settings" tab and click the "Advanced" button. Select the "Monitor" tab and change the screen timing to a different Hertz value in the "Screen refresh rate" menu box. Don't forget to save these settings by clicking "Apply" and "OK" to close all of the Windows settings windows. Hope that helps solve your problem...
Aug 03, 2007 | ViewSonic E70b 17" CRT Monitor
or you have a "crazy" micro or have a stucked push-button (or two) , first I try is change them or at least disconnect it to see what happen.
Jul 11, 2007 | ViewSonic E70b 17" CRT Monitor
Memory recall
Oct 31, 2006 | ViewSonic E70 17" CRT Monitor
Memory recall
Oct 30, 2006 | ViewSonic E70b 17" CRT Monitor
ViewSonic G90fb 19" CRT Monitor Logo
491 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
