Question about Tascam DP01 All-In-One Recording Package Microphone
Need to clean up a DP-01
Hi, I just bought a used DP-01 and want to clean it up. The sliders seem to be running on sand paper and I was going to use 'canned air' to blow them out. I'm a PC technician and wanted to know if there was any 'hidden danger' in opening up the system. If not, what type of product should I use for detail cleaning and can I 'lube' the sliders? Thanks for all your help!!!
Craig
  • la rana Apr 21, 2009
    I was able to open the unit but the sliders are on the wrong side of the system board. I blew out the dust, but do you have any idea how I can apply the silicone gasket lube?
    Oops, I forgot to thank you. thanks!
    President:
  • 1,489 Answers
The only danger I can think of is static shock destroying components.
I would clean it with isopropyl alcohol.
You can relube the sliders with silicone gasket lube.
Posted on Apr 21, 2009
TASCAM DP-01 won`t startup
Press and hold down the "track edit" and the "shut down" buttons while turning the power on until it says "-init screen- please wait". It will ask you if you want to initialize hdd. If so press yes/enter. This Will wipe your hard drive clean. If no just press no/exit. This works on the dp-01fx. It should work on the dp-01 as well.
Dec 02, 2014 | Tascam DP01 All-In-One Recording Package...
Power slider will not work. changed heater core and something might not have gotten reconnected.
The power slider, check the spring switches on the door jamb. They will probably be very corroded, even green in color. Use course sand paper, and clean both sides. As for the heater core, what is the concern? No heat? gurgling noise? no fan speed? oolant leak?
Jan 26, 2011 | 1995 Chevrolet Lumina Apv
Sand paper pad no longer holds the sanding disk
If pad is hook and loop style use compressed air or clean nylon brush to clean debris from hooks.If using adhesive backed dics try wiping a little alcohol across the pad surface to clean it.
Jan 09, 2010 | Dewalt DW421 5'' orbital sander
How do i take the headlight lens off so i can clean on 01 dodge dakota
If you are just cleaning the outside there is a kit with very fine sand paper and a uv protectant at the auto parts house. If you still need to remove the lens the screws are very hard to ge to and underneeth the bumper once removed you will need to seal them back with rtv.
Aug 12, 2009 | Pro-Fit Pro.Fit Dg 71 01 Dodge Dakota...
Need help DP-01 basic hook up to synthesizer
Midi on the DP-01 is only for time synching with another device, synth, etc. To hear your synth through the DP-01 run a 1/4" patch cord from the audio outs (R and L) on your synth into the A and B inputs of your DP-01. Then assign the inputs to tracks and arm them for recording. You should then be able to hear your synth playing out of whatever you are using to monitor you DP-01 (headphones, stereo or powered monitors). To record the synth output simply press play and record together on the tascam.
bd.
Feb 21, 2009 | Tascam DP01 All-In-One Recording Package...
Using the dp-01 as a interface mixer
If you're asking about being able to use the DP-01s knobs and sliders to control the virtual knobs and sliders on some PC recording software the answer would be 'no'.
But if you just want to use the DP-01 to act as a mixer for incoming signals (like microphones and or guitars or other instruments) the answer is 'kind of'. The DP-01 cannot act as a usb interface for your PC, but it can sit in front of a usb interface or sound card and act as a mixer of sorts to mix input from instruments through the monitor outs and then into your computers sound cards or usb interfaces audio-in jacks. You are however limited to two simultaneous inputs though as that is all the DP-01 can handle.
Cheers.
bd.
Oct 20, 2008 | Tascam DP01 All-In-One Recording Package...
Failure to read WAVE file when trying to import a track.
Wav files need to be in mono to be imported into the dp-01. Fruity Loops and a most other programs by default save wav files in stereo. You'll need to save the files again as mono wav files before attempting to import them into the dp-01.
Cheers.
bd.
Jul 16, 2008 | Tascam DP01 All-In-One Recording Package...
Headlights are foggy inside how do i clean them
the fogginess is caused by oxidation on the outside. normal wear and tear.
This is what i did on my honda civic 1996- bought three sand paper 600-1500 and 2000. Bought plastic shine from autozone and some plastic gloves.
1) I cleaned it with diluted soap to get all the dirt out. Use soft cotton cloth to do this.
2) get some clean water and dip sand paper(600) and start sanding the headlight. sanding should be done in the same direction throughout. I used horizontal strokes. Don't let the sandpaper dry out.
3) clean it out with water so all the sand particles from the sanding is cleaned out.
4) start with the next grade sand paper and repeat the process till you are satisfied and the fogginess is gone.
5) clean it thoroughly with water and let it dry fully.
6) put in gloves and rub plastic shine all over the headlight and leave it to dry. Make sure it does touch the paint!! you can mask the sides to avoid that.
7) clean it with soft cotton or polishing cloth. It really works!!!
Also, stay away from direct sun while doing this. Having the hood up is helpful.
Lis
Jul 12, 2008 | 2001 Mercury Grand Marquis
Panasonic Workio DP-1820P
Printer Error E02-01 appears when paper tray number 1 lift-up motor is unable to lift papers, Check whether the gear box of the motor is broken , normally replace the whole unit
Apr 30, 2008 | Panasonic Workio DP-1820E Copier
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Tascam DP01 All-In-One Recording Package Microphone Logo
49 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
