Question about Pioneer PDP-6010FD 60 in. Plasma HDTV
I can't get it to power on.
The standby button is on and I get it to power on. The advice is go to the service menu to reset it. How do I get to the service menu? I have a Pioneer 1080i.
You press menu or you can take the plug out the wall and plug it back in
Posted on Apr 21, 2009
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Jun 25, 2011 | Televison & Video
Bottom portion of screen is cut off. How do I reset the tv?
Hello
To reset your Sony TV, you have to enter its service menu options. It is very dangerous to enter into the sevice manu of any TVs, without proper knoledge. Factory reset option is described in the service manual of your TV. I'll give you the procedure, but be caucious, not to change any value of other paramters, some times the set will turn irreparable. Do only the things I describe here. Actually, this should be done by any experienced service technician. So BEWARE.
To get ito its service Menu
[1] Put the TV in standby mode. (Power off).
[2] Press the following buttons on the Remote Commander within a second:
DISPLAY /Channel 5/ Volume +/ POWER On.
The service menu displays
[3] Use the [DOWN] button to view the next category listing the white balance
adjustment items
[4] Continue pressing the [DOWN] button until the next category list displays
[5] Press the button to select TEST RESET options
May 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
My ps3 wont display the screen but when i use the service menu it works
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Samsung lcd faults
Found this on FixYa and it worked:
I had a similar problem and the way to solve this is to reset the set from the remote. Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Peter
Mar 10, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Frozen digital screen
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Pioneer PDP-6010FD 60 in. Plasma HDTV Logo
361 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
