Question about Dell Dimension 8300 PC Desktop
Power button mulfunction?
Hi all, My 8300's power button has been acting strange; it requires a few pushes to turn on the computer. The frequencies increased last few days and now it completely refuses to repond. I checked the connector on the system board, checked the cable and called Dell Tech Support; but still can't figure out what's the problem. Dell Technician suggested changing the power supply, but he is not sure if that's going to solve the problem. I am thinking perhaps the power button is not working, but I don't know how to take off the front cover to examine it. Dell Technician suggested going to a repair store, but that's going to costly and not necessary helpful. Hope someone can help me here. Thanks. Skyer
  • BRUCEUSA Dec 19, 2007
    I solved a similar problem today. My Dell laptop (Inspiron 8600) was becoming more and more difficult to power on, requiring more and more pressure. The problem, it turned out, was oxidation inside the micro switch. In my case, the solution was to get to the micro switch, GENTLY lift to one side the metal cover which encloses/caps the switch, & remove the rubber tab. At this point, I found a silver disk which I removed from the switch and discovered was tarnished. I placed the disk (tarnish side up) on a cloth towel and removed the tarnish by rotating a pencil eraser 6-8 times. When I reassembled the switch, the laptop worked like new. Total time: 35 minutes. This problem has been concerning/bothering me for months, so I'm really pleased . . . and wanted to share this with everyone who's having a similar problem. Bruce (b.cohen@vanderbilt.edu)
  • boxerjack11 Apr 11, 2009
    I have the same problem with my Dimension 8300, I had been on my computer for a while it then suddenly shut down. I have no idea to see if it has overheated but I have unplugged it and left it, turned it back on but nothing is working i also have the flashing power button. It has been a few days since it has last worked. I dont know if i have blown something on the motherboard or anything like that. Please help me!
  • 62 Answers
Most front covers have screws that hold them to the chassis. Unscrew the screws and be careful not to break any wire connections to your front panel. Then you'll be able to examine the power switch.
Posted on Sep 22, 2007
HP 1315 printer won't turn on
I have an HP printer too, but it's HP 2050. When i plug it in it usually makes a noise and then the power button blinks. To turn it on requires me to hold the power button down for a few seconds until the power button light stays on. If you haven't tried yet, try pushing down and hold and see if it turns on. Hope this helps :)
Apr 20, 2014 | HP Photosmart 8450 InkJet Printer
If the battery of my laptop is low i plug the ac power but still not operational
Hi Paul.
There are few possible causes for what you've described:
1. The outlet doesn't work properly - Try using a different one.
2. The power adapter is mulfunctioning or doesn't match your laptop - try using another original adapter or a generic one (make sure the Voltage is EXACTLY the same as your laptop requires and that it supplies enough Current).
3. The battery has gone bad or finished it's life-cycle - Replace the battery.
4. There's an electric problem with the power circuit on the motherboard - replace it in a service center...
Good luck and best regards,
Pelu.
Aug 18, 2010 | Computers & Internet
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Flat screen monitor functioning strangely
Sounds like there maybe bad caps on the power board in the LCD. Try a different monitor on your computer and if the known working monitor comes on with the computer and behaves properly then you know its a problem with your original monitor. If the known working monitor acts strange as well then you know its a problem with the video card. Let me know what happens.
Jun 11, 2009 | E-Machines eMachines Desktop PC
How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
May 14, 2009 | Dell Dimension 8300 PC Desktop
Computer has shut down and can not re-start
The Dell 8300 does not use industry standard parts. You need Dell specific parts in order to replace the fan. Here is a link to a replacement fan shroud assembly for your Dimension: http://www.discountelectronics.com/index.php?l=product_detail&p=845
You may be able to find cheaper if you do a Goggle search and dig deeper. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 14, 2009 | Dell Dimension 8300 PC Desktop
ok, to get at the switch board, take a flat bladed screwdriver and /carefully/ lever the outside ends of the hinge covers vertically upwards. Once the covers are free (you'll find that they are attached to the blue strip), slide the blue strip and hinge covers to the LEFT and then lift. The strip should free from the chassis. The switch board should be held in by two screws (one holds a lug to hold down the keyboard) and connects to the motherboard via a ribbon cable. The part number for the switch board is printed on the upper side of the board. You might find it advantageous to order a new ribbon cable as well; both parts should be readily available from your newarest independent service centre or direct from Dell.
Oct 20, 2008 | Dell Inspiron 5100 Notebook
Sansui RZ 8300 AV Receiver will not turn on flicker on and off. Power turns on but when the standby button pushes in it just flickers on and off.
Hi curtmalm
First, do a rest on the unit by disconnecting from the wall overnight. Then fire it up again to see if it recovers. Let me know here how you go.
regards
Graeme
Apr 14, 2008 | Audio Players & Recorders
Camera acting strange.
i have the same problem. wat did u end up doing with it?
Nov 04, 2007 | Olympus FE-210 Digital Camera
My E-125 isn't working properly...
If your craddle has DC power input that charges the PDA while in craddle, try setting the power configuration so that when the PDA is on external power, there is no blank screen timeout, and no automatic shutdown (it's in the Settings menu). This way, it won't power down while in craddle, and you won't get this problem you're having.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
Dell Dimension 8300 PC Desktop Logo
252 people viewed this question
Clive
Clive
Alun Cox
