Question about Fuji FinePix A350 Digital Camera
Xd picture card
Bought new card. when inserted in camera states card not initialized
  • 5 more comments
  • mcjr Sep 22, 2007
    I did try that but cannot find anything in settings that reads memory card. Did find format and it went through formatting with hour glass.
    card not initialized memo disappeared but when I tried to take a picture it said writ error.
    Turned camera off and when I turned it back on card not initialized came up again.
  • mcjr Sep 24, 2007
    thanks for the help but found out that my fuji
    A340 will not take an M or H memory card without an update on the camera which I intend to do.
  • Anonymous Dec 31, 2007
    same issue but with a full card. did the format, hr glass ran and had
    to erase all pics and then it reset the number of pics available for my
    card. the initialize message disappeared and then it worked fine.
  • Eldest Nick Feb 15, 2008
    Ok, So my family bought a brand new M xD card for our A340 FinePix Fuji camera. The camera keeps reading, and I quote,"Card Not Initialized". If some can give me a step by step answer of where to do and where to go to initialize this card.
    Thanks much.
  • jasonburrick Jun 19, 2008
    Card, when inserted in camera says card not initialized
  • joemsuya Oct 02, 2008
    I bought my xD-Picture Card in Rome when I began using it it could not take any picture the waord " card not initialised" came up. I decided to format it but same situation happens.
  • dfog May 01, 2009
    I have the same problem but how do you upgrade the camera?
    Brigadier General:
  • 6,966 Answers
Hi, You have to go to the menu/setup function. Check the different settings. One of them would lead you to the memory card settings, from there you should be able to format the new card. Good luck and kind regards.
Posted on Sep 22, 2007
  • Louie  Role
    Louie Role Sep 22, 2007
    Hi again,
    What you did was basically correct. Apparently the card is at fault. Since this is a new card, perhaps you should demand a replacement. Another way to verify if the card will work/format is to use a memory card reader attached to a PC. Some desktop PCs and/or laptops have this already built-in to the system. Slip in the new memory card and let the PC format and diagnose.
    Cheers.
SOURCE:
Keeps saying card not initialized why ?
It just means that you need to format a new card in the camera before it will work properly. Go into the menu and find "format"...follow the on-screen instructions.
Apr 26, 2010 | Fuji FinePix A605 Digital Camera
Display says card not initialized when a new xd picture card is inserted in the fuji fine pix A340 how do i initialize or format the card
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/ you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Jul 08, 2009 | Fuji FinePix A340 Digital Camera
I am getting a message that reads "card not initialized". It is a new XD picture card. How do I initialize the card?
To initialize the new XD card, you go into the camera's setup menu and navigate to the format function. Format the card and you might be ready to go. If your new card has an "M" or an "H" preceeding the XD, your camera will need a firmware upgrade before it will recognize the card. Here's a link to the firmware upgrade procedure. http://www.fujifilm.com/products/digital/download/a340/fupd.html
Jun 15, 2009 | Fuji FinePix A340 Digital Camera
Screen reading memory card not initialized
It sounds like your XD card is corrupted. How and why i couldn't tell you. You will need to get the pictures recovered from the card using a special software (image recovery software, can down load for free from some web sites, or some companies can try and do it for you) and then try and format the card in the camera. DO NOT FORMAT THE CARD BEFORE YOU RETRIVE YOUR IMAGES. If you do all traces of the images may be lost.
All the best and happy snapping.
Aug 20, 2008 | Cameras
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 31, 2008 | Fuji FinePix Z2 Digital Camera
    NEW CARD
    You will need to do a firmware update to be able to use your new 'M' XD card. Also you will need a AC adapter to be able to use the update for your camera.
    It is a Fuji site and it works.
    Good luck.
    http://www.fujifilm.ca/x3719.xml
    May 26, 2008 | Fuji FinePix A120 Digital Camera
    Xd picture card
    Good luck.
    Xd picture card
    Greetings FredericoIV,
    A common fix for this issue is to use an external card reader, and reformat your card using your computer. Make sure you chose FAT format instead of FAT32 or NTFS.
    I hope this helps.
    Thank you,
    Agent Dort
    Go Ahead. Use Us.
    Apr 17, 2008 | Fuji FinePix A500 Digital Camera
    I cannot get card to work in my fuji finepix a 340 says write error inserted Olympus Xd picture card . ASfter attemting to take picture, rec'd message that it could not initialize.
    If your new xD card is an "H" or "M" type card, it is only compatable with the A340 following a firmware upgrade to the camera. http://www.fujifilm.ca/x3721.xml is a link to the software and steps you can take to perform the upgrade.
    Mar 13, 2008 | Fuji FinePix A340 Digital Camera
    I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
    Mar 07, 2008 | Fuji FinePix A330 Digital Camera
    Fuji FinePix A350 Digital Camera Logo
    240 people viewed this question
    Top Fuji Cameras Experts
    Ekse
    Steven Wander
    Steven Wander
    Azam Ali
    Level 1 Expert
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
