Question about Tyan Trinity S2090 Motherboard
Computer keeps re-booting while installing any operating system
Computer had a power supply failure. After installing a new power supply, computer kept re-booting. Tried to wipe out harddrive and install fresh xp.
Loads up to the point where windows says it will reboot, remove any floppy disk in A drive, then keeps re-booting. Since then, i have swapped out 3 different harddrives, 4 different pc133 mem's, 3 different cpu's (2) 1.5G's P4 and one 2.0g celeron. (2) different video cards, (2) different cd drives, (2) power supplies, and a NEW motherboard. I have attempted fresh loads of XP on each darddrive and all fail at the same point, tried '98 this completly loads but then starts re-booting, and linux from an live cd and it reboots during loading. I've tried disconnecting every piece of hadrware not necessary...
Anyone have any suggestions? Both motherboards are tyan s2090.
  • 3 more comments
  • casey460 Apr 21, 2009
    3 total power supplies...
    downloaded new bio, no change...???
    300w power supply...
    that's possible, but this computer ran for years on the same watt power supply???
  • Nicolas
    Nicolas May 11, 2010
    Hi Again!
    That 300w is enough to at least start and install OS on one disk, if you add more disks and maybe a powerfull gpu it will fail, but for now it will work.
    Well, since u you almost changed every hadware and it still dosent work, it only remains one thing to try, the HDD, try with another HDD
    You changed the ram, psu, cpu and the MoBo, there isent mutch left that can fail, only the HDD.
    Let me know how it goes
    Nic
  • Nicolas
    Hi!
    Well, thats an old MB you have there, i suggest you download and install new bio, You can download it from here
    http://www.tyan.com/archive/support/html...
    Nic
  • 371 Answers
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Posted on Apr 21, 2009
  • 1 more comment
  • Maurice B Thomas
    Maurice B Thomas Apr 21, 2009
    Based on nic's observation, have you checked to determine that the new power supplies are not overrated for the older motherboard, as your Core duo and newer CPUs plus all the peripherals might have tempted you to supply greater power than that for which the board is rated?
  • Maurice B Thomas
    Only 300W?? Forget what I said about overpowering the board, as the opposite is apparently true.
    With the load you described, 300 Watts is WAY TOO SMALL. The power supply that small also explains why you had a power failure,as the power demands were in excess of what it could supply.
    You need at least 400 Watts or more but make sure not to exceed the power supply max of the board, although the board's components will make appropriate demands depending on your available power and the supply will conk out when reaching its max.
  • Maurice B Thomas
    Maurice B Thomas Apr 22, 2009
    You have added components and a more powerful and power hungry CPU along with data and software which increases the spin on your harddrive requiring more power than you used to use and the power supply you have is no longer adequate.
    Try a 400 Watt unit, as the more technically complicated method of power metering and monitoring during use is more trouble than you need to determine that 300 Watts is kinda small for today's needs.
    A little history.
    The first IBM PC issued in August of 1981 was considered overpowered at 65 watts, but that was 28 years ago, literally Ancient History in computing.
After installing a new hard drive in my desktop computer, it still does not work. It says no boot device available. Sata's 0 & 1 installed but 2 & 3 uninstalled
No boot device available means the boot device hard drive on your system has no bootable operating system installed on it, or it is faulty. In the BIOS setup program, does the computer recognize the hard drive you installed, and is it included in the boot device list? If you installed a new hard drive because of a failure of the C: drive, the new hard disk does not come with an operating system. You have to install that on the new hard drive from the manufacturer's system restore disks. SATA channels 1 and 2 are just the connections on the motherboard for devices, and usually have a hard drive on one connection and a cd rom drive on the other. Giving the model and manufacturer of your computer might provide more clues.
Feb 04, 2017 | Hard Computers & Internet
Tip
Instaling operation system when a Sata Hdd is not seen
I will show a trick about how to install an operation system when you have an erased sata Hdd ..and cause of the lack of a raid driver it is blocking the boot and not let you boot even from cd ...
Insert the boot-able installation cd ...choose to boot first from cd ..and to trick the computer just remove the power supply from the Sata Hdd ...This way you will make it go on and boot from cd ...Keep in mind that the primary drivers and files that are loaded when the installation starts ..are not stored on the hdd..so it will not see the drive missing ...after it starts to load files...and before getting to the agreement ..just plug the supply back to the Hdd.. in this point the primary drivers will be already loaded ..and the computer it is already seeing the hard drive ...and will continue the installation like on any other one without any problems...
Good Luck !
on Feb 02, 2010 | Computers & Internet
Keeps saying media test failure and no operating systems found
Im assuming you have an installation or a recovery disk Insert the Windows install disk for your version of Windows and reboot the PC. With the computer unable to find the operating system on the hard drive, it may skip automatically to the next possible boot device, which should be the CD or DVD-ROM drive. Some systems may be configured to boot to that source first, and others may not be configured to roll over to the next device at all. When in doubt, there should be an option to select boot device when the computer is first powered on (the F12 key on most Dell computers) and you can boot straight to the optical drive from there. Press any key when prompted to boot to the install disk, then follow the on-screen instructions. You'll want to try to perform a repair on the existing Windows install, which you will get to by first selecting a new install of Windows. Select to install a new operating system, and the install package will look to see if Windows is already installed. If it finds the existing install, the installer should give you a chance to perform a repair of what's currently on the hard drive, replacing corrupted files with clean ones from the install disk. If the Windows installer does not detect an existing Windows install on the hard drive, then the hard drive itself may be at fault. Replace the hard drive and repeat the first few steps to install Windows from scratch. The original hard drive is likely corrupted or otherwise broken, and may not be recoverable at all, outside of an expensive, third-party data retrieval service.
Mar 16, 2013 | Lenovo Computers & Internet
Says network boot failure ;not reading my hard drive please help me someone thank you
Here the reason why youre getting the error message the system is not reading the operating system on the hard drive.Heres some thing that you can do.
Change your Computer's boot sequence in you Bios. Make sure that you select a device (Hard drive) that has boot files (or Operating System files) installed. If still cant boot you might need to reinstall a new operating system to your machine. Keep in mind that if you reformat the machine all the save files on the drive will be wiped out
Thanks for using Fixya
Jan 27, 2011 | Acer Aspire One AOA150-1949 Laptop
Computer wont boot up, power light comes on but wont recognize monitor. just before it started doing this , the computer would come on and start to boot up, when the windows status bar came up the computer...
there are many reasons for this problem i want u to tell me that did u install any program before this happened or power failure leading to immediate shutdown.
problems can be
1.there might be problem with due virus
2.it might be a problem of hardware failure of harddisk
3.it can also be that there might be bad sectors created on hard disk
right now what solution i can provoide is if boot from cd and try install fresh copy of operating system.u will have option of formatting only the c drive keeping rest of the drives with your data
Jul 06, 2010 | E-Machines (308714) Motherboard
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Unable too logg into the system
sounds like a hard disk issue try booting from the original s install disk . the see if you can reapir the installtion
if it still can recognise the disk you probably have a hard disk problem. Eithe buy or get a techical person to call out and check the hard disk for you.
if you have win xp boot to the cd then choose repair at the first menu , when you get to the dos screen type in
chkdsk /f and let it do what it must to complete.
hope this helps
Jan 02, 2009 | E-Machines Emachine T5026 power supply **...
Hi i am tryning to load an operating system onto my brand new hard drive. It keeps coming up with disk boot failure, insert system disk and press enter.. what do ido
Hi, By brand new harddrive, I assume that its fresh and empty.
You need to install the Operating System (OS) in that harddrive.
You can do that my inserting the OS installation CD/ DVD into the drive before you bootup.
If you still get the error, get into the setup mode and change the boot sequence to boot from CD-ROM first.
Hope it helps :)
Sep 21, 2008 | Computers & Internet
When powering up my computer, I get a failure. Primary hard drive 1 not found Strike the F1 to continue F2 to run the set up utility. I think the power supply fan is not working. What do I do?
your system can not detect your primary hard disk which host the operating systems,so you check the data cable to the hard drive and the power supply to the hard drive for supply
Jul 19, 2008 | Computers & Internet
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Tyan Trinity S2090 Motherboard Logo
113 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Robert Graf
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
