Question about Philips HTS3450 System
Home theater system
My subwoofer wont turn on for nothing. i cant figur out whats wrong but i did hit the system with my coffee table and i think it pushed the power cable into the speaker further than it is suppose to go. i dont know if its a blown fuse or what. Can some help.
  • Anonymous Dec 04, 2007
    same problem philips sucks
  • 20 Answers
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Posted on Jul 26, 2008
SOURCE:
Dvd player and cd work but no Radio or tv sound also hooked up a turn table and that wont play. Help
Hi, i think you have to get your unit looked at as it looks like the solder joints are drying up.
Feb 26, 2016 | Sony DAV-HDX266 Theater System
My Boston Acoustics ASW 650 just turned off yesterday and wont turn back on. What could be wrong?
Check for the wires connections on all the terminals.
Else it is a minor problem due to power fluctuations.
Take it to a nearby technician.
Sep 22, 2014 | Boston Acoustics ASW650 10in 650 Watt A...
Protect subwoofer showing on power amplifier
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Feb 03, 2014 | Sony MUTEKI HTDDW1600 Theater System
I have a subwoofer JVC TH-C5 it dosen't turn on i oready change all fuse from the subwoofer what else you think is the problem
I would first check the wiring from the amplifier to the head unit (stereo Deck). If that connection is loose or not there then the sub-woofer will not turn on.
Mar 13, 2013 | Audio Players & Recorders
I have a pioneer home theater HTZ585 DVD system. Since yesterday, i get 'SUB COM' message displayed (blinking) and nothing seems to work anymore. Any suggestions?
I can't find that message in the manual but I would guess it's trying to tell you something is wrong going out to the subwoofer. Trace the wiring. If you don't see anything wrong, disconnect the sub and see if the message disappears or changes.
Apr 30, 2011 | Pioneer 740 DV Home Theater System System
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
Home theater system
A broken connector or power cable is the problem....accordianman
Sep 22, 2007 | Philips HTS3400/37 System
Philips HTS3450 System Logo
160 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
