Question about Rinnai RHFE-556FAIII 21,500 BTU Ductless Energy Saver Heater - RHFE556FAIII Air Conditioner
Heater not heating at the right temperature?
I recently received a Rinnai RHFE-556FAIII. It was working fine now it will not heat up one room in the home. When at first it warm the whole house at 72 degrees. Even when I turn it up on high it will only heat two room luke warm.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Sir,
Your heater is only a 21K BTU heater. It is not meant to heat a whole house. We don't know how big you house is, however a 21K heater will not heat 4 or 5 rooms. The best you could expect out of a Rinnai 556 would be to heat a couple of rooms that are next to each other. You will never be able to heat rooms in your house that have doors or are down the hall a ways.
Good luck,
Tom Hawkins
hawkins111@gci.net
Posted on Apr 22, 2009
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Tom
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
I rent and have a Rinnai Energy saver 556F. I have it at 64 and the light blinks for 68. I would like to know why. It is 56 out side now thank you
Shadow,
The 68 you see is an error code. It means you have had an over heat situation. You should be able to clean the filter and fan area and restart. Turn the heater off and on again, that should reset everything and you should be good.
Tom
Oct 06, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
New heater has worked but now lights up then immediantly goes out
There should be a flame sensor similar to the one below. The tip will be directly in the flames. Try cleaning that with a piece of steel wool and try the heat again.
Mar 24, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Heater slow coming back on after having reached temperature.
lower the tempature setting so the residual heat is the right temp your looking for
Jun 20, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Our heater seems to have therostat set low. We are cold.
not sure if this unit has any type of sensor to protect you from carbon monoxide but if it is ventless and operates on gas it may be tripping on sensor any ventless unit must be operated with fresh air for combustion
Apr 06, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rennai 551 FA-P Never fully shuts off
Hebert,
Is there a chance there is a draft around the room temp probe? It is down low on the right side of the heater. If there is a draft the room sensor is fooled and keeps running the unit. You should be able to prove the room sensor by putting your hand over it after the stove has been running for a while. This should shut the stove down. If not there is a problem with the room sensor.
Tom Hawkins
hawkins111@gci.net
Jan 25, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I ahve a rinnai enersaver 1004f model gas heater and i recently noticed that after several minutes sometimes just 2 minutes, the heater stops giving heat and the number 14 shows from the small LED where...
#14 is the code for over heat. Clean the circulating fan and blower blades. If there is anything on the top of the heater it need to go. Check the sides to make sure nothing is obstructing the air entering the back of the unit.
Tom Hawkins
hawkins111@gci.net
Jan 17, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Oct 29, 2008 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
Rinnai RHFE-1001FA
I can suggest a around-about solution. I also have the same model installed around the same time. I have the outlet that it is connected to controlled by an electric heat thermostat on a wall at the oposite side of the room. I keep the heater on high at all times and the thermostat controls the electricity to the outlet. It's worked great for the 13 years it's been installed.
Mar 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
220 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
