Question about Akai LCT2721AD 27 in. LCD Television
TV won't power up unless I unplug it and then pluc it in again.
When I attempt to powr up, the stand by light just stays red . . .. either with the remote of the console mounted on/off switch.
  • Anonymous May 01, 2009
    I have the same set - it's the Power Supply located inside the set - upper left looking from the back of the set.
    The capacitors on the board are shot and need to be replaced so PCB needs to be removed and sent for repair.
    Several eBay sources for this repair HOWEVER the connectors are hot-glued in and are very fragile therefore difficult to remove w/o damaging the PCB. As an alternative, get a heat-gun and warm up the connectors before attempting to remove the stubborn ones. Also, a craft-knife w/narrow, sharp edge helps but may damage the connectors.
    Recommend paying a TV repair shop to remove the PCB for you - MARK THE CONNECTORS FOR LATER RE-INSERT - then send the PCB for repair - reinstall yourself when it is returned.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Follow this guys advice. I did it and it worked. My first TV fix and I did it. http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Posted on Sep 09, 2009
Samsung plasma tv made a really loud pop and the screen and sound do not work but the red power light won't come off unless the tv is unplugged what happened?
The main power supply regulator board has the fault. Check if any electrolytic capcitor/s has bursted out. Replace them if any. If this do not help you. repalce the board as card basis.
Replacing it as card basis is fine, rather than making 'surgery' to it.
May 28, 2012 | Televison & Video
My 40' vivo tv has turned off and won't turn back on but the red stand by light is on??
If the standby light is on and it does not respond, it is most likely to be a problem with the power supply . First try this, unplug and leave the set like that for a few hours. Then plug it back in to see if the tv attempts to turn on when you try to power it up. See if you hear a "click" even if it goes back to standby. Let me know what you found so that I can help you test the power supply board to confirm, if necessary.
Aug 18, 2011 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Jan 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Stand by light is on but won't turn on
something in the tv is blown try unplugging it for 30 min then try again
May 08, 2008 | Polaroid 2611-TLXB TV
Akai LCT2721AD 27 in. LCD Television Logo
181 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
