Can't communicate with scanner
I have had the printer since Jan 3, 2009, and it has worked like a dream. This morning I turned it on and received the message "scanner error. turn printer off, wait a few seconds, turn back on. See documentation." I turned the printer off and on about 10 times with no luck. I disconnected and reconnected all cables. I tried plugging the printer directly into the wall rather than a power strip. I restarted my computer. I downloaded the most current printer driver and scanner utility directly from Epson. I restarted my computer several times. Nothing has worked. Please help.
SOURCE: Lexmark X 1270 Can not Print
try reinstalling the driver
Posted on Dec 20, 2007
SOURCE: I cannot get my PIXMA
http://software.canon-europe.com/software/0028481.asp
For any pilgrims lost on the path, and trying to follow the map above, here is a major road not marked
- the actual link here takes you straight there! I couldn't get it from the canon website, I got it by searching for 'scangearmp-common'.
Posted on May 03, 2008
SOURCE: Lexmark x5470
I have no CD in order to reinstall the USB device. The machine copies and now prints, but not scans!!
Posted on Sep 18, 2008
latinmcgyver
  • 208 Answers
SOURCE: Printer unable to communicate with computer
most easiest fix for this.. make sure in the properties of that printer.. under the PORT tab. make sure its set to usb not LPT. this is very common error.
Posted on Oct 10, 2008
  • 85 Answers
SOURCE: Dell Color Printer 725 - Communication Not Available
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Posted on Jul 29, 2009
What printer can I purchase that is compatible with magic jack, so i can receive fax
HP Officejet 5610.
However, you need to turn off the ECM and set the speed to the lowest. That should work.
However, I would still suggest to contact HP to verify this. Because, HP Officejet 5610 will only work (to send or receive fax) if you're using the older version of the Magic Jack. DO NOT use the software version that was release last Jan 2010.
Thank you and good luck!
May 21, 2010 | Office Equipment & Supplies
I receive a cannot connect to pc when I press the button to scan. What is causing this error?
Hi
Sounds like your scanner is not longer connected to your PC- have you checked that the scanner is plugged into the PC. They can move an get dislogged
also check that the PC is still registering the scanner by
  1. Close all applications.
  2. Open the all-in-one product Toolbox, an icon on the desktop, or in the program group for the product.
  3. Select the Services tab.
  4. Select Test Product Communication.
  5. When complete, and the test passes, open the application you want to scan into, and select the Scan option to verify the fix. For a list of the applications that support this feature, see the document "HP ScanPicture Utility Overview and List of Supported Applications."
  6. If this does not work, uninstall and reinstall the software. Consult the User's Guide for assistance.
When communication is lost to the product (for example, the power was turned off and on), some features are lost. Running the communication test re-establishes communication between the computer and the product. Regards Liz
function submitTo(f) { var msg=""; var message; var helpValue=""; var easyValue=""; var i=0; var index=0; var flag=1; var f = document.feedbackForm var radio1 = false; for (i=0; i") != -1 ) { m = m.replace(">", "-"); } if (m.indexOf("") ==-1) { flag2=false; } } f.comments.value=m; // JAGaf87381- Document Feedback doesnt accept Greek input // f.comments.value = escape(f.comments.value); f.submit(); }else{ } }
Feb 22, 2010 | HP OfficeJet r80 InkJet Printer
Answer
Your software can't communicate with the scanner, check on your computer for other scanning software, Picaso should work with it and it comes standard on Vista machines.
Sep 15, 2009 | Canon MP610 Photo All-In-One Printer
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Sep 21, 2008 | HP ScanJet 3500C Flatbed Scanner
Scanner
1. try to print a test page.
2. if test page ok, turn of all of your firewall application, then check if panasonic communication utility is running as seen
on task bar (blue colored icon near at the volume control)
3. if it is running, double click it (PCU). scanner configuration must appear
4. the scanner configuration details about how you receive the document (popup or etc), program to open (you may even use adobe pdf reader), and the display name of your computer that will be seen on scanner directory of the machine.
May 22, 2008 | Panasonic Workio DP-3530 Copier
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
SCANNER ERROR
Generally all in one devices have problem with drivers!!! The main problem is communication between computer and printer!! Try to find another driver or reinstall the old ones!!!
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
91 people viewed this question
jasbo
jasbo
