Question about RCA P46921 46" Rear Projection Television
Blue, green, and red colors all off
I have a RCA 46 inch TV Model #P46921 that recently started having issues with the convergence being off. There is red, green, and blue lines are all messed up. Sometimes you can fix it by unplugging the TV and plugging it back in. I tried going to the menu of the TV and adjusting the picture by going to the screen menu and then going to "Adjust Projection TV" so that I can fix the red, green, and blue colors...but my TV no longer offers this on the menu. It has in the past but it doesn't any more??!! Does this require a repair person to come out and fix it and how much on average should it cost??
  • happy35 Nov 18, 2007
    We have a 72 inch rca rear projection television. I can go to the adjust projection and the red will let me go from side to side b ut will not let me go up and down. Please can u give me a suggestion on how to fix this problem?
  • Kimberly Castro
    Kimberly Castro Feb 09, 2008
    omg....i have the exact same problem...how does an option like "adjust projection" no longer be offered to you? where can i go to get it on my menu. red, green and blue are slightly off. i use to be able to get a grid of some sort... help
    Genius:
  • 1,139 Answers
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Posted on Sep 22, 2007
SOURCE:
My convergence is not good how i can adjusting it
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2011 | RCA P46921 46" Rear Projection Television
I have a 46" rear projection Mitsubishi TV that recently started producing a wavy picture. The reds, blues, and greens separate into wavy color bands distorting the picture. It usually goes away for...
your problem is most probably in convergence circuit.  very common for this model to have convergence output i.c.'s go bad  also possible that a fused resistor or two has failed.
Jul 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Green color board replacement
if its the board that attaches to the center gun its called green crt pcb
Apr 13, 2008 | RCA P46921 46" Rear Projection Television
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
Convergence issues
di you check the resistors right next to the s these usually go out with the ICS
Feb 02, 2008 | Sony KP-46WT500 46" Rear Projection...
RCA P46921 46" Rear Projection Television Logo
206 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
