Question about Frigidaire FEF352 Electric Kitchen Range
Starts beeping and F31 ERR flashes
I can't find my owners manual. The timer will start beeping and flashing F31 ERR. I turn it off and a few minutes later it starts again. What does F31 ERR mean?
  • mahjo Apr 21, 2009
    The message & beeping started in the middle of the night when we were not using the stove/oven.
  • 39 Answers
Its a shorted probe connection.
check resistance at room temp if less than 500ohms replace rtd sensor probe.check for shorted sensor probe harnessbtween EOC and probe connector
Posted on May 22, 2009
  • 13 Answers
Any F code error indicates a fault has been detected . Press Clear/Off to clear display and stop beeping then reprogram the oven. If the fault reoccurs record the fault number press Clear/Off and contact an authorized service agent. If you have access to the internet you can download a manual for this appliance go to www.frigidaire.com/support/support.asp
On the customer services page click on product manuals and you will be abe to download the manual and print it off.
Posted on Apr 21, 2009
I cant get my oven to stay on model # FFEF3015LSM after a few minutes is turning oven on, it starts to beep and screen says F30
It looks like the probe is the same as the temperature sensor.
On some models, you can recalibrate the oven control up to 35 degrees Fahrenheit higher or lower. Refer to your owner's manual for instructions on how to recalibrate the oven control.
Since you're getting an error message the following may apply:
OPEN PROBE CONNECTION
1. (F30 or F31) Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
SHORTED PROBE CONNECTION
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. .
Possible Replacement Part:
http://www.repairclinic.com/PartDetail/Frigidaire-Range-Stove-Oven-Temperature-Sensor/316490000/1197392?modelNumber=FFEF3015LSM&fromRepairHelp=True&ss=a13b2d1284938
Mar 24, 2016 | Ovens
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
Washing machine keeps beeping then all lights and screen start flashing.
i would guess that you have a faulty main board, the quickest and surest way to determine the problem and that is to replace it with a second hand board out of an known old machine which has faulty seals.
Dec 11, 2011 | Fisher and Paykel Washing Machines
Timmer switch turns on but pump does not start. I have to go out and turn off timmer swith for a few seconds and turn timmer back on and pump usually starts auto matically. Some times when timmer switch...
The flashing re light is trying to tell you what is wrong! It will flash 2 to 9 times and you need to count the flashes and then refer to the troubleshooting chart on page 27 of your owners manual.
To me it sounds like your pump loses it prime some I would suspect a leak on the suction side of the system.
http://www.inyopools.com/manuals/210/IntelliFlow4x160_OM.pdf
Jul 20, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
How do I reset the clock on a Taylor timer 5891-21?
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
Nov 17, 2010 | Taylor Hardware & Accessories
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Mar 01, 2009 | Hitachi RAS-09UH Air Conditioner
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
'Err' & 'E"
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
Sep 23, 2008 | Nikon N80 35mm SLR Camera
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Frigidaire FEF352 Electric Kitchen Range Logo
1,179 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
