Printronix Line Matrix P5005B Printer Logo
A
Anonymous Posted on Oct 03, 2013
When printronix printing starts after 15 to 20 mints printronix given the testing hardware error how to resolve
harjindar
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 80 Answers
  • Posted on Jan 08, 2015
harjindar
Expert
Level 2:
New Friend:
Cheetah:
Answers
80
Questions
Helped
25552
Points
106
Logic card is faulty
1 Related Answer
RoryMRP
Rory Cardenas
  • 111 Answers
  • Posted on Jul 07, 2009
SOURCE: error msg says "COLD PRINT HEAD"
1. The Printhead/Controller
cable assembly is
disconnected.
2. The environment is too cold
for the printhead to sustain
operating temperature.
1. Make sure the printhead/
controller cable assembly is
connected to J401 at the
printhead and J6 on the
controller PCBA.
2. Move the printer to a
warmer location.
If none of this works you might have a bad printhead. The thermistor on the printhead has gone bad and needs to be replaced.
Please contact me if a printhead is needed or if you have any other questions. I am also an ASR for Printronix meaning I can supply you with new and used parts and printers.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
[email protected]
AOL IM: RORYMRP
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
tip
Unable to Print on HP Printer
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click ->> HP Print and Scan Doctor to download the Utility and save on Desktop location
Run the HP Print and Scan Doctor file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
* Please rate this solution with Thumbs up and comment to help us improve providing support
Hardware twsting msg ??
Your Main Board (called a CMX) has failed. You can google
"PRINTRONIX 157450-991 PWB,CMX,V 5.5 40MHZ,EXCHANGE,P5000 "
For the part, but the part will require software either pre-loaded or you will have to get the file to load, ask about that before you purchase this or it will not work when you get it.
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Error msg says "COLD PRINT HEAD"
cable assembly is
disconnected.
controller PCBA.
warmer location.
Thanks
Rory Cardenas
Alsip IL 60803
708-597-4222 x240
[email protected]
AOL IM: RORYMRP
2answers
Printronix
i have problem in winxp for printer proline sereis 5 printronix line printer driver not match
in custom size
so need for printer driver winxp supported
Printronix T5000r Label Syntax to print " character
It is a syntax error.
It should read:
D;POINT;075;095;12;6;"text"
You might be able to get away with this:
D;POINT;075;095;12;6;"test";"text"
quotes have to be in sets of two and elements have to be seperated by semicolons.
Printronix printer connected to scounix server
culd be a emulation problem or maybe spooler configuration
2answers
Printronix P5412 Do not Print
Sounds like this unit has some electrical (minor) damage.
Top Printronix Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
