Dell Inspiron 8200 Notebook Logo
Pee Kay Mensah Posted on Oct 03, 2013
MY LAPTOP DELL INSPIRON 8200 SCREEN LIGHT KEEPS BLINKING, WHAT COULD BE THE PROBLEM??
shouadkoch
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on May 14, 2014
shouadkoch
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
2707
Points
22
It can be 2 things: Or the screen is dying, or the graphics card is dying. Try to start up with an external screen and see if it still blinks. When its still blinking on the external screen, your graphics card is dying, if the external screen shows no issue, then your screen is dying.
5 Related Answers
Anonymous
  • 66 Answers
  • Posted on Dec 01, 2007
SOURCE: Problem Dell Inpiron 5160
Hello Maciekpl,
This is Romeet,i would like to try and help you solve this, please let me know if you have a replacement motherboard for your laptop ready? also let me know how comfortable would you be with opening up the thing and replacing it?
B.Regds
Romeet
Anonymous
  • 124 Answers
  • Posted on Dec 02, 2008
SOURCE: Want vista Driver for Dell Inspiron 8200
Everything you need is here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_P4_8200&os=WW1&osl=en&catid=&impid=
Download the files you need on a computer that works, copy them to a usb storage drive or burn to a cd, and put them on the laptop.  I cannot upload anything for you.
Anonymous
  • 43 Answers
  • Posted on Jan 24, 2009
SOURCE: dell inspiron 1100 laptop screen won't light up
Sounds like a back light problem, power reset it, pull out the battery and ac adapter and then hold the power button for 1 minute, then replace the power cord and battery and start it up, if it doesn't work try calling dell to see if you can get it repaired under warranty if it is out of warranty take it to a shop.
Anonymous
  • 29 Answers
  • Posted on Feb 28, 2009
SOURCE: dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
Anonymous
  • 83 Answers
  • Posted on Oct 11, 2009
SOURCE: dell inspiron 6000 battery light is orange
remove the battery and insert again. if it continues then you will have to check the power source perhaps current it not enough for charging, if it continues then you will have to get a new battery
Testimonial: "Thanks for the help. That is what I expected."
Power comes on and then off after only a few
if u say the battery is the problem then first solve that the ill help with the battery which can be only done by replacing them!!
then reply and rate!!
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
I accidentally disabled the screen
try booting in safe mode and do system restore up to the last good working date of your laptop. . .
hope this helps.
1helpful
My dell 8200 inspiron laptop right speaker its not working
My guess is the speakers or connectors have gone bad. I have seen this in a lot of different laptops.
If you are handy, you can disasemble the laptop, find the speakers, and get a part number off of them. Dell is pretty good about labeling the part numbers. Then do a search on Google and Ebay for the speakers, I am sure you can find some cheap used ones that work.
Here is a manual for disassembly of your laptop, and shows where all the parts go. You will need Adobe reader to read this.
http://www.elhvb.com/mobokive/edwin/laptops/Dell/INSPIRON/8200/8200.PDF
Gray screen
alternate click on " MY COMPUTER" then properties, the hardware, then device driver, click on video , alternate click on the unit and select updae driver
2answers
Boot problem
sounds like a bad driver-can you boot into safe mode? how about the bios?
Dell Inspiron 8200 Won't Boot up. Not even to BIOS.
Latitudes sometimes have a problem with RAM. Try these things to get it to boot...
1. Remove the RAM modules, clean the contacts with a pencil eraser, reseat modules and test.
2. If two modules, remove one and test. Place same module in second slot and test.
db
Dell Inspiron 8200 Battery
I assume that you have your charger plugged in as long as you use the laptop...
There are very minimal chances o the battery having been damaged, since the casing on the inspiron 8200 is quite sturdy.. i suggest you get the charge socket (the socket that leads to the main wall electricity outlet) from a qualified technician...
Dell inspiron 8200
Yes buy a PCMCIA adapter card. You can search yourself or just buy one here
Good luck and remember please rate this post
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
