Question about Brother HL-5280DW Laser Printer
Dots on page
Hello, my problem is that whenever I print, I have 3 dots on the right side of the paper that get printed. They run throughout the paper, generally in different spots on different papers though. Thanks in advance for any assistance.
    President:
  • 2,022 Answers
Shivan, did you change the toner if it yes then open printer and clean the surface of toner and the roller see is there any dust or ink powder is there. bye
Posted on Sep 22, 2007
SOURCE:
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
There are 3 small dots that print across each page when I print. How do I get rid of those?
what type of printer, laser or inkjet. are the dots spaced down the page or across?
I suspect you have a laser and the dots are down the page in which case it is most likely the fuser unit or the cartridge.
To verify which, you can send a print to the printer and open the printer half way through. If the dots are present before the paper goes through the fuser (the hot bit that fixes the toner to the page) then its the catridge, otherwise it will be the fuser unit. you will need need to replace which ever part is the cause
Sep 02, 2011 | Brother Office Equipment & Supplies
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
It prints three dots on the left side of the page every time.
These dots may be called as "Garbage Valley"
This means ur printer has got lots to print but it was stopped due to certain reason.
I'll ask u to go through ur printer manual & print atleast 5 pages of garbage valley & while u do this, i'll ask u to reinstall ur printer driver.
Hope it works out.
Thanks
Sep 01, 2009 | Brother HL 1440 Laser Printer
Printer prints a colour dot at every pages edges
Hi ,
if u get red dots on print it may be problem with Red cartridge Lick age please check u r printer with Ok cartridge .if same problem with new cartridge then u need to clean Mirror built in lance assembly
Jul 11, 2008 | HP LaserJet 3800dn Printer
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
Brother HL-5280DW Laser Printer Logo
410 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
