Question about HP Officejet 5610 All-In-One InkJet Printer
I'm getting a error that states.Internal DRS error 1500:c0:3001 after scanning a document while I am saving it.
  • 21 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd3
Posted on Sep 06, 2009
3 Suggested Answers
marlen56
  • 110 Answers
SOURCE: Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Posted on Aug 28, 2009
SOURCE: internal drs error 1500:c0:3001
I changed OCR language from English (United States) to English (United Kingdom). Then on "Scan To:" option, change to "Microsoft Word". Save shortcut as "Text to Word". There is even an icon option for this, and then save shortcut. Great sense of relief.
From Big GL.
Posted on Feb 03, 2010
After the scan, the program cannot save the file.
Alright, Open the "paint " program from all program/accessories/paint".
click on the file and click on the option scanner and camera wizard after that you will get a option for "scan" please click on scan to make and change and once when scan get complete. click on file and click on the save as to save the document.
good luck.
Nov 13, 2009 | HP PSC 2355 All-In-One InkJet Printer
I have an Officejet 5610 All-In-One and when I am trying to scan, while processing, I am getting "Internal DRS error 1500:c0:300". How can I solve this please?
Search the HP knowledge base for more ideas. You didn't say if that error message is showing up on your computer or on the LED panel of the printer.
Sounds like your trying to scan a document. Make sure the application that is supposed to receive the document is installed.
Oct 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Problems with Age of Empires II
I think the game may need direct x to run
Problem apple does not have direct x
research on internet is pointing to emulating windows on Mac
and running dirext x in emulation ?
https://www.parallels.com/au/landingpage/pd/general/?gclid=CjwKEAiAi-_FBRCZyPm_14CjoyASJAClUigOnIf36NPJH6HLhU3gR7pjCfXoq_M5fkmTj1iGAnEpAxoCOH_w_wcB
Mar 05, 2017 | Macsoft Video Game Consoles & Games
When scanning I get the following error internal DRS error 1500:c0:3001
hi,
1) go to Add/Remove Programs: Remove all HP Software.
2) Manually search for/remove all HP program files.
3) Run my Registry cleaner.
4) ONLY IF YOU KNOW WHAT YOU'RE DOING : Manually search the registry via Control F function for any remaining HP registry entries.
5) Defragment/re-install/run reg. cleaner/carefully analyze and save appropriate registry keys(see my pic's for what to definitely save).
6) Defrag. again
7) Test run HP Solution Center again.
Sep 19, 2009 | Computers & Internet
I'm getting a internal drs error 1500:c0:3001 when I am trying to scan my old documents into emails or wordpad. Paper has watermark and shaded areas. All in English
See if you can update your TWAIN compliant driver at www.twain.org... if you are using OCR (optical character recognition) software, you may want to first scan to a Word .doc (OCR tends to scan text in "clusters", like text-boxes, and your wordpad or email client may not recognize the multiple "boxes" of text...
Hope this helps!
-- RT
Sep 03, 2009 | Office Equipment & Supplies
If not
Success!
Aug 28, 2009 | HP LaserJet 3600n Printer
Internal drs error 1500:c0:3001
Try change the OCR language.
I had the same problem (HP Deskjet F4280, error code 1500:c0:3001) scanning documents with danish language to PDF and OCR language set to English. Changing OCR language to danish solved the problem.
PaulPS
Apr 13, 2009 | Office Equipment & Supplies
I'm getting an error:Internal DRS error:1500:c03001.PLEASE HELP!
You need to change the resolution on the scan to 200 dpi. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. or create a new "default" profile because it wouldn't let you modify the installed setup sometimed without saving it under a new name.
Apr 13, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
When I scan a document on my HP deskjet f2210 and the document is
I recommend uninstalling all HP components from your add/remove section in the Control Panel - restart computer - and then reinstall from the original disk sent from the manufacturer. Do you still have the disk?
Mar 26, 2009 | HP Deskjet F2210 InkJet Printer
Using HpDeskjet f2280 All-In-One Printer, Scanner, Copier. When scanning have error message "Internal DRS Error 1500:c0:3001
You need to change the resolution on the scan to 200 dpi. I submitted this to HP and that is what they told me to do. It works. The steps to do it vary according to your HP Solution Center software version. Just find the "Scan to PDF" settings. In my case, I had to create a new "default" profile because it wouldn't let me modify the installed setup without saving it under a new name.
Oct 30, 2008 | Computers & Internet
HP Officejet 5610 All-In-One InkJet Printer Logo
440 people viewed this question
Seeker5211
Seeker5211
