Question about Toshiba Tecra 9000 Notebook
Tecra 9000 will not power on any more even with ac power
Even with the ac power all i get is a yellow light flashing at me with the battery in it or not and my battery isnt charging dont know wht to do help please it was working fine then one day nothing
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
I left my laptop on last night unplugged from the battery, downloading something. I got up this morning, and the laptops power light is flashing orange. I tried switching it off, but it wouldnt turn on or...
If your laptop was sitting on a bed, soft chair or something similar it probably just got too hot. Let it sit for a few hours before attempting to power it back on.
Jan 05, 2011 | Toshiba Tecra 9000 Notebook
My toshiba tecra 8200 will not turn on when i hit the power butto tne green power light changes to a flashing yellow and stays that way
the power pack or the battery needs to be replaced
chrck the out put of the power pack with a volt meter to see if the output is fine
if so replace the battery
Radio Shack will test the power pack for you if you can not
Jun 27, 2010 | Toshiba Tecra 8200 Notebook
My Tecra Toshiba will not turn on or off, even plugged in.
Yes it is. And, it is highly recommended that you remove the battery if you're going to use your laptop for more than 1 hour. If you keep your battery in and have the laptop connected to the adapter, the poor battery is going to be charging/discharging so much that its life is greatly shortened. Also, this is what causes dead cells in batteries.
You might possibly have an internal power supply problem.
But, go ahead - remove the battery. See if it helps.
You also might try letting the battery charge for 3 hours with the laptop off.
Oct 12, 2009 | Toshiba Tecra A1 Notebook
When i power on my tecra 9000 it lights up and thats it
You may have faulty RAM.
Try reseating the RAM modules first. If this doesn't work remove the RAM modules and ask your friendly computer shop to test them for you.
Sep 20, 2009 | Toshiba Tecra 9000 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
When using ac adapter to my Tecra 8000 the power light is yellow
Try a new battery and if the new battery wont charge then its either going to be a bad ac adaptor or a bad motherboad. If the new battery charges then you'll know that the old battery went bad.
Mar 29, 2009 | Toshiba Tecra 8000 Notebook
Flashing Charging Light on AC Power
shortage on the motherboard, needs new motherboard.
Mar 09, 2009 | Toshiba Tecra 9100 Notebook
Toshiba Tecra 9000 WiFi
it's a wireless connection set up issue..in control panel, among last icons..follow that direction..should get you there.
Apr 21, 2008 | HP Pavilion dv6000z Notebook
Toshiba Tecra 9000 Notebook Logo
203 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
