Question about Bosch 24 in. SHU43 Built-in Dishwasher
Stuck in drain cycle
When I push the on/off button on, the pump tries to drain even though there is no water in bottom of unit. It runs continuously. It is as if the sensor for the water level is telling the pump that there is water but there isn't. It starts without me even hitting one of the wash buttons. Help!!
  • ddbuild Sep 25, 2007
    the anti flood sensor had triggered the pump. I emptied the water out of the overflow pan and bingo the pump stopped because it didn't think there was an overflow issue anymore. I was able to splash out some of the water and stuff a small rag into the pan which sucked out the rest of the water.
  • 209 Answers
Continuous pump action is a sign that there is another fault with the machine, generally its a faulty heater element, test accordingly hope i have helped, if so please rate, me, be safe unplug when working on any appliance
Posted on Sep 22, 2007
SOURCE:
Drain pump running continuously even with no water
You might want to try manually filling the machine with water using buckets or a hose. Perhaps there is some type of switch that is stuck on. My thought is that if you fully load the Machine with water and let it run through it cycles it may somehow reset the switch. It's worth a shot.
Dec 26, 2013 | Washing Machines
Dishwasher stuck on drain cycle
Hello, If your dishwasher is stuck in the drain cycle there could be two reasons for the unit doing this. The first reason is you could have something clogged in the drain line or blocking the drain pumps impellar. If the unit is not able to empty the water out of the unit the drain pump will continue to try and empty the water. The second reason would be if you had a leak condition in which if you did have a leak the drain pump would continue trying to empty the unit to prevent the unit from leaking water outside of the unit. I would first remove where the drain line connects to your drain and inspect this area first if you do not find any blockages in this area you would have to de-install the unit from under the counter and check the oppisite end of the drain line to where it attaches to the drain pump itself. If you still found no blockages you would then remove and inspect the drain pump assuring that the impellar of the drain pump is spining and that there is nothing clogging the pump as well. If you have any further questions message me back. I await your reply
Thank you
Rick
Nov 28, 2011 | Danby DDW1805W Designer Series...
The power will not shut off
Usually in a miele dishwasher when the power does not shut off this is due to a leak condition in which the pump is trying to pump any access water due to a leak out of the unit in which the drain pump of the unit will run continueously to avoid water to come out of the sealed bottom and spill all over your floor. One of the first things that would distinguish if this were the case in your unit, would be if you could hear the drain pump running. This can also happen if you have a clog either in the drain pump or in the drain line or in the port hole where the drain pushes the water into your disposal. If you do not hear the drain pump running. As to the door latch it basicly tells the control that the door is either opened and not to turn on the cycle or closed and then to turn on the cycle and begin to wash. You can also check to assure that you have no leaks by pulling the unit out by deinstalling the unit and removeing the bottom base panel to see if there is any water inside. If you find there is no water and no clogs and you do not hear the drain pump working message me back for further diagnosis. I await your reply.
Thank you
Rick
Nov 02, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Hi I have a problem with my Bosch SHU43CO6UC/22 dishwasher. using "power scrub plus" and "regular" cycles it will continue to fill and overflow the door, after the cycle has run even...
The bosch dishwashers use a fill valve that is attatched to the inlet hose. yours is stuck in the open position. this usually happens when you have hard water, as the minerals build up on the sealing surface of the water valve. there is no easy fix. the fill hose will have to be replaced. It requires removing the machine, removing the bottom pan, and changing the hose connections.
the valve uses water pressure to stay closed. if the water pressure is very low coming in, it may not be enough to close the valve. there is a filter screen between the fill hose, and where it connects to your water valve. try cleaning the filter out and see if that makes a difference. If not, you will have to get the hose changed.
Nov 19, 2010 | Dishwashers
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working...
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Nov 11, 2010 | Bosch Dishwashers
Drain pump won't turn off
The reason the drain pump continously runs is because it is trying to remove any water too avoid any further flood as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Jan 24, 2010 | Bosch Dishwashers
FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
Jun 16, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Front loader with F02 problem
CHECK THE DRAIN MOTOR PUMP it could be clogged, need to open washer , locate drain motor , youll see the drain hose connected to it , inspect , clean and replace , AJ
May 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 running constantly
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
238 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
