Question about Intel D845GEBV2 Motherboard
I need a a video graphics adapter (VGA) to my computer. the graphics is so poor after formatin. where could i find it?
  • 151 Answers
Check intels website or type your MB type in google, I always find them there but better see the graphics chip number and get drivers for it instead.
Posted on Apr 21, 2009
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
Standard VGA graphics adapter
> standard VGA graphics adapter
Windows shows this when you have not added a hardware-specific device-driver for your video-adapter. Double-click that entry.
Click "update driver". Click "yes" to "access the Internet to search for an updated driver".
Or, give us more information on the manufacturer of your computer, the manufacturer and model-number of your video-card, and the Operating System that you are using.
Oct 22, 2010 | Computers & Internet
Just received Refurbished Advent CBE 1401. It is being replaced because power switch is faulty - but I have questions about machine. 1. When initially switched on the switch turned red is this normal? I...
1) No. The switch color should have been Green
2) No Signal on the monitor, indicates the monitor is not receiving a Video Signal from the computer.
A) Could be due to a faulty monitor cable.
Monitor cable is used on a working computer for a test,
Or,
working computer's monitor cable is used on the Advent for a test.
B) Could be due to the graphics 'engine' on the motherboard, or on the graphics card is bad.
[Graphics 'engine'.
GPU
Graphics Processing Unit.
http://en.wikipedia.org/wiki/GPU ]
If the computer is using Integrated Graphics, the GPU is on the motherboard.
(Integrated Graphics is also referred to as OnBoard Graphics. Meaning On the motherBoard)
You will know if it's Integrated Graphics, because the monitor cable will be plugged into the VGA connector, on the motherboard
http://en.wikipedia.org/wiki/VGA_connector
Since you indicate an adapter was included, to adapt to a different port (Connector), it could be a VGA to DVI adapter, or a DVI to VGA adapter.
Your monitor may just have a VGA connector on the monitor cable.
Hence you would use a female VGA to Male DVI adapter.
Your monitor may be an LCD flat screen monitor, and has a DVI connector on the monitor cable.
Hence you would use a female DVI to Male VGA adapter.
DVI
Digital Visual Interface
http://en.wikipedia.org/wiki/Digital_Visual_Interface
VGA monitors are Analog.
LCD monitors are Digital.
A computer puts out a digital signal.
If a VGA monitor is used, the computer has to alter the Digital signal to an Analog one.
This slows down the video signal.
If your monitor (In any case. Not just this one), is an LCD flat screen monitor, it is best to use a DVI monitor cable, and plug into a DVI port on the computer, if available.
If your monitor is a VGA (CRT. Cathode Ray Tube), monitor, and you have a DVI connection on your computer, using the adapter will do you no good.
The adapter just uses the contact pins for VGA, that are present in that DVI adapter, and hence the DVI connection on the computer.
You're still just getting an Analog VGA signal.
Example of a female VGA to male DVI adapter,
http://www.directron.com/dvi.html
If the Integrated Graphics are suspected to be bad, a graphics card is used in the appropriate expansion slot, for a test.
If the graphics work then, the graphics card is left in service.
After I test the monitor cable my next procedure is to suspect the Power On switch, or the Power Supply, and go to the graphics next.
The reasoning is that Power Supply failure, is the number one cause of computer failure.
The next is the Power On switch, then Electrolytic Capacitors used on the motherboard.
(Specifically, any Electrolytic Capacitors used in the motherboard Voltage Regulator Circuit)
If the Power On switch is bypassed, the diagnosis will reveal if the problem is the switch, or Power Supply.
Bypass the Power On switch, and the Power Supply comes on?
Problem is the Power On switch.
[One Power On switch I have found to fit a lot of computers. The Power On switch goes into the plastic Power On button,
http://www.directron.com/atxswitch.html ]
Bypass the Power On switch, and the Power Supply does Not come on?
The problem is the Power Supply.
The Power On switch is bypassed using a jumper wire, from the green Soft Power On wire, to ANY black Ground wire. The contact made is a brief momentary one.
The jumper wire is used at the back, of the 20, or 24-pin ATX main power cable connector.
To be continued in an additional Comment.
Jun 04, 2010 | Computers & Internet
No video output from atapi dvd rw after OS reinstall, cd rw ok
>> VGA controller (vga compatible) error in the device manager
Windows has not found a "good" device-driver for the "integrated" video-controller on your motherboard; it is using the "generic" adapter.
So, trying to download the "SIS Mirage Graphics" software is an attempt by Windows to download a "specific" device-driver that matches your video-adapter hardware.
You might try installing an add-in video-card, to see if Windows will install the correct device-driver, and still boot-up correctly.
Otherwise, take the computer to a qualified technician, for trouble-shooting about your boot-up problem.
Mar 03, 2010 | Computers & Internet
We have Dell OptiplexGX745 smallform factor desktop computers that we need to run two monitors.
If your Dell Optiplex GX745 came with the ATI Radeon X1300 graphics card, that has One - DVI graphics port, and One - VGA graphics port, it's no problem.
This link shows an ATI Radeon X1300, and the two above mentioned graphics ports,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5550932&CatId=28
(Please scroll down to the larger photos for more detail.
The Radeon X1300 graphics card in your computer, is a Low Profile graphics card. It will not look exactly like the one shown.
Low Profile means shorter in height. Your graphics card is shorter in height, in order to fit in your SFF computer case. {Small Form Factor}
The longer white connector shown on the left side of the view, is a DVI port. (Technically it's a Dual DVI port)
The shorter blue connector shown on the right side of the view, is the VGA port.
1) If one of your monitors has a DVI connector plug, simply plug it into the DVI port.
If the other monitor also has a DVI connector plug, you will need an adapter to plug it into the VGA port.
2) If both of your monitors have a VGA connector plug, one will plug into the VGA port on the graphics card.
The other will need an adapter to plug into the DVI port, on the graphics card.
This link shows an adapter for connecting a monitor with a DVI connector, to the VGA port on a graphics card,
http://www.directron.com/dviadapter.html
The adapter to connect a monitor with a VGA connector, to a DVI port on the graphics card is opposite of this.
[ I have found them at Radio Shack.
This = Expensive! $14.99
Not advertising for Radio Shack, or the above website in the link]
NOTE*
Use care when selecting the adapter you need.
A monitor with a VGA cable connector has the Male pins.
Your adapter must have the VGA Female sockets.
The DVI side of the adapter must have the Male pins.
It goes into the Female socket holes on the graphics card.
Same with a monitor that has a DVI cable connector.
The adapter must have Female DVI socket holes.
The other side will have Male VGA pins.
If your ATI Radeon X1300 only has One - graphics port, I Do Not advise using a splitter.
This is an adapter cable that has a connector on one end, and splits into two cables.
The graphics quality will be poor.
If you have No graphics card the situation is worse. This is Onboard, or Integrated Graphics.
(OnBoard. On the motherboard)
Using a splitter cable will result in very poor graphics.
How to tell if your Optiplex GX745 only has Integrated Graphics?
Look at the back of the computer. Come down from the audio ports. (Green and Blue)
Look under the USB ports.
The Blue VGA port is the Integrated Graphics port.
If you have an ATI Radeon X1300 graphics card, you will see a blue VGA port in an adjacent slot, also.
(Your computer can have Integrated Graphics, and a graphics card.
You CANNOT use the Integrated Graphics port, and a graphics port on a graphics card, At The Same Time!
It will Not work)
Once the two monitors are attached.
1) Turn both monitors on.
2) Turn the computer on, let Windows load
3) After Windows has loaded, Right-click on any empty area of the desktop screen.
4) Go to the bottom of the drop down menu, and Left-click on Properties
5) There are tabs across the top. Left-click on the
Settings tab.
6) You will see two rectangular icons. These icons represent monitors.
The one on the left side with the white border around it, is your Primary monitor. The main monitor you have always had.
The grayed out icon on the right side represents a Secondary monitor. This is for the second monitor you plugged in.
Note how the two monitor icons are sitting.
Primary on the left, Secondary on the right.
This is how your monitors should be sitting.
If it is Not, left-click on the Secondary monitor icon. Hold the left mouse button down, and drag it over to the left.
Now scroll down this window with your eyes.
Under the resolution settings you will see -
Extend my Windows desktop onto this monitor
There is a square box to the left of it.
Left-click in the square box. Go below to the right, and left-click on Apply.
Now go to the left, and click on OK.
Your monitors will now both be showing your desktop screen.
[Note* When doing this procedure, you have clicked on the Secondary monitor icon. Clicking on the icon activates it]
When you open the internet, or have a program going.
Go to the right side of the screen to the blue border,
of the Primary monitor.
When the mouse cursor turns into a double-headed arrow, hold the left mouse button down, and drag the screen to the right.
(You will note that the mouse cursor changes quite easily. It has to be double-headed in order for this to work)
If this direction does not work, go to the left side of the screen, drag to the left.
(You have to drag in the direction your monitors are actually sitting, in relation to each other)
Need some clarification, or have further questions? Click on Comment.
Jan 14, 2010 | Intel computers9: P3 Computer Computer...
My monitor will lose its signal from the computer and won't come back on even after I tighten the cables are replace them with different ones. Sometimes it works, sometimes it doesn't.
the most likely problem here is that the computers video card is failing, if it is a name brand computer like Dell, HP and so on the video card is built into the motherboard which will have to be replaced to correct the probem, the only way to confirm this is to hook up your monitor to antoher computer and see if it wotrks ok, if it does the motherboard is bad.
Jan 06, 2010 | Computers & Internet
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
I have 2 acer data managerment problem found in edata security software installation it says please close all running programs and reinstall edats security. the second one is catalyst control center is not...
Close programs (word-processor, web-browser).
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click on EDATS SECURITY (or something approximately that)
Click Remove
Click OK
Shutdown
Restart
Reinstall the software
> catalyst control center is not supported by the friver [?]
> version of your enabled graphics adapter.
ATI (www.ati.com) distributes the "Catalyst" software with their adapter video-cards. So, there is a problem with the "Control Center" component of their software.
> please update your ati graphics,
> or enable your ati adapter using displays manager
First, do you have an add-in video-card in your computer?
If not, then you should not be trying to use the ATI software,
and you should remove it:
* click Start
* click Control Panel
* click Add/Remove Programs
* select the ATI Catalyst software
* click Remove
* restart your computer
Second, if you have added an ATI card, you may need to restart your computer, press DELETE to enter BIOS SETUP, and "disable" the "onboard" video-adapter, or change the video-priority so that the ATI video-card becomes the "primary" video-adapter, and the onboard video-adapter becomes the "secondary" video-adapter.
Then, click Save Changes, and before selecting Exit From Setup,
move the video data-cable from the onboard VGA port to the VGA port on the ATI video-adapter. Then, "blindly", click Exit, and let your computer restart. Then, during the reboot, the ATI software will recognize the new "primary" video-card, and will the software will control the ATI video-hardware.
Sometimes, it helps to have a second computer monitor, and connect one adapter to the "onboard" VGA-port, and the other to the ATI VGA-port, so that you can see video output wherever it is produced.
Nov 09, 2009 | Acer Computers & Internet
Resolution goes back to 800X600X75 sva 20" LCD
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | SVA-USA Computers & Internet
Problem with Standard VGA Graphics Adapter
You need to install the drivers for the graphics card that you have. Search for the drivers on toshibas website.
Jun 24, 2009 | Toshiba VGA Board Graphic Card
Intel D845GEBV2 Motherboard Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
