Question about JVC GR-D350 Mini DV Digital Camcorder
Jvc gr d350 - how do you deal with 'safeguard mode' what is it?
How do you get out of it?
'take out and re-insert the cassette - in safeguard mode'
makes the camera unusable........
  • luke706 Apr 23, 2009
    that seemed to work every now and then - thank you very much!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Remove battery / power source for few minutes and attache battery / power source again and check.
  • 10,594 Answers
Thats good.
Posted on Apr 23, 2009
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
The cassette holder wont come up aoutomatically
what you have to do is ejecting the tape, and as soon as it starts to eject , close the door immediately, then safeguard mode should be gone, and you will be able to eject normally.
Mar 04, 2008 | JVC GR-D290 Mini DV Digital Camcorder
JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Sep 16, 2009 | JVC GR-D370 Mini DV Digital Camcorder
I have a jvc digital camera GR-D350 u i don't know how to get the cassette in?
How do I change the GL- DPF8005A Digital piture frame from chines to English.
Sep 09, 2009 | JVC GR-D370 Mini DV Digital Camcorder
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Digital video camera stuck in safeguard mode
model # gr-d396u is stuck in safeguard mode, how do you unstick it
Apr 05, 2008 | JVC Cameras
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E03 safeguard mode
look for a tiny pinhole and insert a pin while powered up to reset
May 27, 2007 | JVC Cybercam GR-DV800US Mini DV Digital...
JVC GR-D350 Mini DV Digital Camcorder Logo
404 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
