Question about Frigidaire Dryers
Frigidaire affinity model AEQ7000EG 0 DR error
I am receiving an error DR on my dryer. From what I can find it is the dryer switch. Where do I find the service manual to look up this part number and how to fix it
Did you find the solution to this
Posted on Jan 20, 2010
My dryer is not heating
THE PROBLEM MAY BE OF SEVERAL THINGS
1. ELEMENT BURNT OUT
2. THERE ARE NORMALLY TWO TEMPERATURE STATS
ONE CONTROLS THE TEMPERATURE/ SWITCHES THE HEATER ON AND OFF AND THE OTHER IS A OVER TEMPERATURE STAT, IF THIS TRIP'S IT WILL NEED REPLACING AND ALSO THE WORKING STAT, THAY COME AS A SET.
3. WIRING CONNECTION ON HEATER ELEMENT BURNT OFF
4. PROGRAMMER CONTACT /CABLE PROBLEMS
MAY BE CHEAPER TO BUY A NEW ONE AROUND £200
GOOD LUCK
Sep 22, 2016 | Frigidaire AEQ7000EG Affinity Series...
My dryer says pf and I just put the clothes in so what does this mean?
On some models pf indicates a power failure. Try unplugging and re-plugging after a short pause.
Aug 17, 2015 | Frigidaire AEQ7000EG Affinity Series...
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Won't spin
The start relay on the motor is bad and you will need to replace the motor. The relay is not sold separate. Here is the motor you need to order.
Oct 30, 2012 | Frigidaire AEQ7000EG Affinity Series...
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Aug 19, 2012 | Frigidaire AEQ7000EG Affinity Series...
Frigidaire Affinity Dryer
try hitting stop clear twice check the door switch see if its working also if you didnt send in your warrenty card then frigidaire dont know when you bought it if youve never had it serviced i was a factory tech for years for frigidaire so you can call them and say you bought it say a week from now and get it serviced let me know what happens
May 17, 2008 | Dryers
Dryers Logo
257 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
