Question about Garden
Weedeater show how to replace fuel line - Garden
  • 246 Answers
Hello:
The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
  • 3 Answers
This solution may apply to most trimmers. http://auto.ifornet.com/trimmer/TrimmerFuelLine.htm
Posted on Jun 12, 2009
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Weedeater, 18cc, replaced fuel line & purge
Check the screen inside the tank to make sure it is clogged. also check the gas cap to make sure the breather holes aren't blocked.
Posted on Apr 18, 2010
I need to replace fuel line in Weedeater trimmer. How can I do it ?
Enter Weed Eater fuel lines in the search field for numerous results and if not, repost here.
Aug 07, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
WeedEater Featherlite String Trimmer fuel leak.
give it a week to see if the fuel hose swell and stop leak sometimes i have the same problem.
and ill wait for a week and it quits leaking.try that
Jul 30, 2009 | Garden
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Weedeater GHT-22 Hedge Trimmer Leaks Fuel Near Handle
Either the fuel lines that were replaced are a poor fit in the tank ( wrong diameter pipe ) or the pipes have been connected incorrectly to the fuel primer bulb.
Dec 13, 2017 | Poulan Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Garden Logo
5,045 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
