Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Radio has no reception
The radio on my car stereo wont work no tp comes up,cd works fine.
  • nacken23163 Apr 28, 2009
    yeah i can hear white noise,no channels can be found even when i manually scan.i think it could be internal damage ill hook up my old radio and see if it works
  • 150 Answers
Stupid question , but check if antenna has come loose if not then you have internal problems
Posted on Apr 21, 2009
  • 1 more comment
  • Jerry Naidoo Apr 28, 2009
    Progressive problem
    1. When you tune what happens does it skip thru all the stations but do not lock ?
    2. I can hear white noise ?
    3. I cannot hear the white noise ?
    depending on your answer here I can probably ppin point your exact problem but you must ensure antenna is in first.
    WELL IF YOU WERE IN SOUTH AFRICA (DURBAN) , I WOULD GLADLY REPAIR IT FOR YOU.
  • Jerry Naidoo May 05, 2009
    good idea bro .
My car stereo wont play my cds spits them right out
cd player goosed if it doesent accept cd can try resetting if it has a reset button
Aug 25, 2012 | Cars & Trucks
Why have I no radio reception on peugeot 307?
go step by step to find the fault.
check antenna connection behind the radio
check roof aerial and wire connection underneath it.
Take an old radio's antenna and connect it to your car's radio antenna input and check whether your car radio is working properly.
Apr 15, 2012 | Peugeot 307 Cars & Trucks
Ihave a renault megane that has a renault cd/radio fitted. The radio works fine but I have inserted a cd and now it wont come out! please help1
you will need to take stereo to a repair shop they will need to open it to remove the disk and to repair the problem that is causing it.
May 15, 2011 | Car Audio & Video
I have replaced the car radio antenna on 1993 Discovery. Works fine on am very pore reception on fm. The car radio, factory fitted, is Eurovox Model 92039986. Is there an adjustment to tune the radio to...
Check your connections on the antenna again. Am usually gets decent reception. sounds like your antenna connection isnt fully connected either at the stereo connection or at the actual antenna connection.
Mar 29, 2010 | Car Audio & Video
Stereo just shut off and wont come back on???
Yes on the wiring behind the radio, there should be fuse holders there.
Feb 27, 2010 | Panasonic CQ-C7103U CD Player
Fm radio doesn't tune
check that the antenna is plugged into the back of the unit or look under your fender and make sure it is plugged in there as well or use manual search instead of autosearch
Jun 26, 2009 | 2004 Ford Focus
Bosch radio works on AM frequency but not FM
go to their website for answers to solve this problem
Feb 12, 2009 | Bosch PB10-CD Radio/CD Boombox
Bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Nov 01, 2008 | Kenwood KDC-119 CD Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
377 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
