Question about Hoover Dryers
Nextra 7 tumble dryer makes a grinding noise when tumbling
This only occurs when tumbeling to the left, someone has suggested that the belt may need to be tightened - any thoughts on how to do this would be appreciated
Thanks
Peter
4 Suggested Answers
ranger25
  • 72 Answers
SOURCE: tumble dryer not giving off heat
It could be the heat limiter switch which is either one or two run in series little button looking things near the element on the back, usually under a bowed out cover. Also check the resistance on the heating element after you have pulled the wires that go to the terminals so you don't get a false reading. Other than that it gets into checking contacts on the timer itself and that gets a little lengthy in discussing. Hope that helps.
Posted on Jan 28, 2008
yalmer
  • 552 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Nov 12, 2013 | Hotpoint TVF770 Tumble Dryer
My hotpoint vtdoo tumble dryer is making a screaming noise and belt is still inplace and turning.
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Sep 07, 2010 | Hotpoint Dryers
Proline tumble dryer TDC6A makes a loud grinding noise.
Howdy: There is a spring loaded belt tenioner that holds the belt in place. They are plastic with steel bearings. They do go out often do to the surround heat in that area. Good luck - Doug
Dec 09, 2009 | Dryers
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Dryer is working but wont tumbel
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Nov 11, 2008 | Dryers
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
sounds like another problem occured causing your belt to either break or slip off the motor
Oct 25, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
43 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
