Question about Sony Playstation 3 (PS3) Console
My tv shows its's geting 1080i only
I have a Mitsubishi WD-65731 and after hooking up the PS3 and playing 4 Brothers blu ray disc, the info button on the tv shows 1080i. Mitsu rep says it's plug and play and should indicate 180p if it is receiving such a signal. I set up the PS3 to output 1080p in the menu. Is there anything that I may have missed? Thanks.
You must have the HDMI cable to view Blu-Rays in 1080p, with a component cable the console downgrades the signal to 1080i for some reason.
Posted on Sep 22, 2007
    Scholar:
  • 113 Answers
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
SOURCE:
I am having a sony blue ray dvd home thatre bdv e280 bought from switzerland and I came to India which I wan't to play some dvd's bought from India which is is blocked of region code. How to unlock the...
Works with most Sony Players
Step 1
Unplug the power cord of the Sony Blu-ray player. Plug the power cord back in. Turn on the Sony Blu-ray player. Turn on the TV to which the Sony Blu-ray player is attached. Wait for the "No Disc" text to appear on the front of the Sony's LCD display and on the TV's screen.
Step 2
Press the "Eject" button on the remote control. Wait for the disc tray to eject itself from the front of the Sony Blu-ray player.
Step 3
Press the "Disc Info" button on the remote control. Look for a number to appear on one of the upper corners of the screen of the TV.
Step 4
Press the "Disc Info" button repeatedly until the number "9" appears on the TV's screen. This number indicates that the Sony Blu-ray player is now set for "multi-region" and will play any Blu-ray disc that is commercially made.
Step 5
Turn the Sony Blu-ray player off using the remote control. Turn the Sony Blu-ray player back on using the remote control. Press the "Eject" button on the remote control to close the disc tray. Turn the Sony Blu-ray player off using the remote control.
Dec 28, 2017 | Televison & Video
Mitsubishi WD 65731 - where is the thermal sensor connection that sometimes needs to be resoldered?
does not need to be resoldered. needs to be changed! Any tech that is familiar with Mitsu would tell you that. It's behind the lamp area. Should be done by a Tv technician or you may never get it back together. But not expensive to repair. About $150 parts & labor.
Feb 26, 2011 | Mitsubishi WD-65731 65" HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Mitsubishi 55 in. 1080 series
If I remember correctly, this TV has a couple of constraints that will cramp your style:
1. It supports 480i, 480p and 1080i. NO 720P
2. It has component video inputs, but NO HDMI. (as you stated)
There is no easy solution here, because I've never found an upconverting DVD player that would upconvert anything past 480p using the analog component outputs...
So..
Perhaps you can find an Upconverting BLU-RAY disk player that may allow older DVDs to be upconverted to 1080i via the component outputs.
MOST Blu-Ray players allow 1080i output via the analog connections on Blu-Ray discs, so perhaps there is your solution.
Mar 09, 2009 | Mitsubishi WS-55311 55" Rear Projection...
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
How do I put it to 1080 resolution
I have this same TV and a PS3. You either need to get a HDMI - DVI cable, or plug in some component cables in order to get 1080i from your PS3. Your DVD's will upscale to 1080i and your Blue_Rays will run at 1080i, but be aware, if you play PS3 games that only read 720p on the back of the game box, the PS3 will down convert them to 480p instead of upconverting them to 1080i.
Peace, Bob
Jun 21, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Will not display 1080p from a Sony ps3??
Connect your PS3 through the HDMI 2 port on the TV and as a PC under the tv settings. Then auto setup the tv on the PS3 and it will now see it as 1080P. It will give you some error message whenever the PS3 is first turned on but it will work. Hope this helps everyone.
Ryan
Jan 20, 2008 | Mitsubishi WD62627 62" HDTV
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
308 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
