Wash stops, beeping, flashing F and 02
While the wash is running, it begins to beep and F and O2 begin flashing on the screen.
  • Michael Masters
    Michael Masters May 11, 2010
    whats the make and model on this washer?
    Sniper:
  • 88 Answers
I'll just take a swing at this one, without model number.............F-02 is typically a Whirlpool error code for " slow drain". If this is a Kenmore or Whirlpool front loader, pull off the bottom panel and check the pump filter, (pump should be right up front, turn counter-clock-wise to remove filter) clear of any debris, check hose from tub to pump as well. NOTE! If there is water in the machine, it will pour out of the pump, first remove the water either with a wet-vac, or just do it very slowly and carefully at the pump, draining the water into a pan.
Posted on Apr 21, 2009
Pre-Wash and Crease Care lights flashing?
WHILE IT IS LOADING WATER, TRY TO ADVANCE THE WASH PROGRAM; INSTEAD OF LARGE CAPACITY GO TO MEDIUM.
Jun 20, 2015 | Washing Machines
ADL348 is constantly beeping and does not complete cycle
If it beeps continuous and starts on the rinse cycle,then this is indicating the control board is bad and needs to be replaced. NOT THE TOUCH PAD, but the control board.
Dec 17, 2013 | Dishwashers
Whirlpool WFW905OXW pauses and beeps at beginning of wash cycle
Remove the lower kick plate and check the drain filter.
Oct 30, 2012 | Whirlpool Washing Machines
Okay, my fisher and paykel gwl15 is almost brand new. i moved it into my new house tonight. I tried washing my laundry and it starts to fill but then stops at the light that says "wash" and wont...
Sounds like you have low water pressure or a blocked hose inlet screen. take the hoses off and check to see if there is any debris in the screen on the washer hose connection. Make sure the hoses are not kinked and the valves are turned up all the way. Also check to see if you have those special flood proof hoses with the automatic water shut offs. I have had those not work properly many times.
May 18, 2011 | Washing Machines
I have a Bosch Exxcel washing machine which is great but it bleeps for ever and a day when the wash is finished. How do I silence the beeps without having to get up?
Switch machine on but do not program.
Press and hold PREWASH button.
After a few seconds it begins beeping.
Keep holding PREWASH button in until beep gets quiet
then eventually stops.
Hope this helps - Colin, Billericay Essex
Apr 11, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
"tap water closed?" message
Plug off the wall. Check the inlet tubes into your machine (after shutting off wall valve) for any blockage or clogging, both ends of the pipes. Refix carefully with correct threading. Turn on before next wash fully; and after wash turn off valve. It could also be that your wall valve is not on fully when you begin your wash.
And dont forget to rate me pl.
Jul 03, 2006 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
