E drive not working
When clicking properties, it shows that the drive has zero used space and zero available space when there is a cd or even when there is no cd in it. when i enter a cd it does not recognize it
thanks in advance
  • 150 Answers
If the light in front front flashes when you insert a cd it means the optical could be dirty / defective - needs repairs
Posted on Apr 21, 2009
I formatted my iomega helium hard drive but it doesn't show that it has any available space on it, What do I do?
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 You might have to alternate doing this repeatedly until the problem is resolved
This works on usb data drives i am not sure on usb external drives
Apr 06, 2013 | Iomega Helium Portable Hard Drive hard...
Simple yet idiotic: I go to burn a CD-R (in XP), the wizard wizardizes fine, but when I go to open the CD there is nothing on it and Properties shows 0 bytes used space and 0 free space. Device...
I would start by going into my computer, right click on your burner, select properties then the recording tab and uncheck the box "enable CD recording on this device". Windows burning software causes havoc with other recording programs.
Feb 26, 2011 | LG Electronics 16X DVD-ROM IDE ATAPI DVD...
Dvd properties
Try updating the drivers. Go to LG's website and look for support/downloads to find them
Mar 31, 2010 | LG SecurDisc 20x External Double-Layer DVD...
I have installed an extra 1G memory but it has not
Open "My Computer".
Right-mouse-click on the 'C:' drive.
Click 'Properties'.
A pie-chart will display, showing how much disk-space is "used"
and how much is "available".
Probably, the "available" pie-slice is less than 5% of the whole pie.
What Windows did was to "expand" the "paging" file, making it 1GB larger than it was before you added the RAM. So, the amount of "used" space on your C: drive is now 1GB _more_ than before.
So, burn some CD/DVD disks with some of your files,
and then delete the files, after checking that the disks are readable, to make more "free" space on your 'C:' drive.
Jan 09, 2010 | Acer Aspire 5315 Notebook
My printer is printing slowly
Print speed can be affected by three important factors:
Available computer RAM
Available computer hard drive space
The HP All-in-One product paper sensor
Follow the steps below the ensure the computer is operating properly.
Step one: Verifying the amount of RAM
Verify the amount of RAM installed in the computer.
Determine the amount of memory currently in use by background programs or processes.
Programs/processes will run in the background even when no applications are running. Most of these programs/processes will be indicated by an icon in the lower right corner next to the time.
Less memory available for applications will result is slower processing time and consequently, printing speed.
To determine processes running in Windows 2000/XP , do the following:
Press Ctrl , Alt , and Delete simultaneously and then release.
From the Windows Security box, select Task Manager.
Click the Processes tab to view all running processes.
Click the Performance tab to view the total and available amount of memory.
To determine processes running in Windows 98 , do the following:
Open the Device Manager .
Click the Performance tab.
The available system resources will display as a percentage.
Turn off unnecessary background processes.
This will free up system resources and increase printing speed.
To turn off processes in Windows 98/ME/XP , do the following:
Click Start , Run , and type msconfig.
From the System Configuration Utility, click the Startup tab.
Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space
Follow the steps below to determine the amount of hard drive space on the main drive.
Open My Computer , right-click the C drive, and then click Properties .
This will display a chart along with the total hard drive space, used space, and available space.
Verify that there is at least 2-3 GB of hard drive space available.
The computer will require at least this amount to process printing data for simple text files, more for image files. The lower the amount of available hard drive space, will greater the time to process print data.
Step three: Ensuring the paper sensor is clean and not damaged
The all-in-one product paper sensor plays an important role in determining the print speed.
Printing a self-test or demo page will ensure that the paper sensor is in proper working condition. If the page completes in less than 40 seconds, the sensor is working correctly.
Even if the sensor is working correctly, the printer driver might need to have the paper sensor turned off. To turn off the sensor, follow the steps below:
Open the Printer folder, right-click the printer and click Printing Preferences or Properties.
From the Properties box, click thePaper/Quality or Features tab.
Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
This will disable the paper sensor and increase the print speed
Nov 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
Dvd not read
read head tunning problem tune the present in head assembly in CCW direction slowly until it read dvd
Aug 22, 2009 | Computers & Internet
Pen drive cannot open
Please install the usb driver and check again.
Jul 02, 2009 | Electronics - Others
E drive shows full capacity and does not read cd's
It means the CD is not working... Just check with that CD. Write some data in the CD. After writing them put that CD inside and check whether the content is there or not...
Apr 21, 2009 | Computers & Internet
CD /DVD burner not identifying the disc
Hi
Type of media settings might be the issue but making a change for standard CD/DVD recording (it affects reading too) Issue can be resolved. Right click on the CD/DVD drive (Usually D or E drive ) click on properties and select and choose the recording option. Click the enable CD recording for this drive option
Click on apply and OK. Try again. You may try after reboot the computer. If issue persist please post so we can think about some alternate solutions.
Good Luck
Jan 24, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Open Questions:
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
