Question about Nokia N95 Cellular Phone
Unlock n95 need to unlock my phone
  • Anonymous Apr 21, 2009
    I m using N95, I have forgotten my unlock code. can someone help me plzzz
    Sergeant:
  • 379 Answers
Unlock information - Method 1. Unlock your phone for freeThere are many websites which simply list codes for your phone without charge. Many people believe the practice of locking phones is anti-competitive and thus there's a lot of information to help consumers fight back against this.
Who is this for?
The free method works best for older Nokia phones and some other older handsets. Yet its worth everyone quickly trying to see if you can find a code for your phone, though after trying that, go toMethod 2.
Step 1. Get your facts right.
To find a working unlocking code for your handset, you need three pieces of info; its brand/model number, the network, and the IMEI code. Here's how to find them.
  • Brand and model number. Chances are you already know this, as it's likely to be written on the handset, it's box, and any documentation you got when you bought it, so I'll move on.
  • The network. This is simply the network the phone's currently locked to, not the one you want to get on.
  • The IMEI. The International Mobile Equipment Identity is a unique number given to all mobile phones, which gets marked as invalid when phones are reported lost or stolen. To find your IMEI, simply type *#06# into your handset, and note down the number that appears.
Step 2. Find an unlocking code.
There are a raft of websites dedicated to phone unlocking. Which you should head for first depends on your handset brand.
  • Nokia phones. The easiest way to unlock older Nokias is via codes found on sites like Trycktill& Unlock Nokiafree.
  • Other brands. Trycktill lists a few codes for other brands, though no where near as many as for Nokias. Some handsets by other manufacturers are not unlockable by freely-available codes, but it's still worth running a quick Google search to see if yours is one of the few that is (though do check it's a legitimate source). Also you'll find a full discussion of other phone in the Unlocking non-Nokia phones discussion in the Mobile Phone Forum.
    If it transpires that you can't unlock your phone with a free code go to Method 2.
Step 3. Use it!
The sites above will generate a code based on the info you provided, so double check it's right first. The code will look something like this. #pw+2746763089+1# (Nokia phones), or *2767*637# (Other makes).
To unlock, take the Sim card out of the phone and put in a different network's Sim. Now you can put the code in...How to enter the code.
Rather than using the regular text keys you need to use the * key if you want to produce letters as opposed to numbers. To produce a ‘p', press the * button three times within two seconds; to produce a ‘w', press the * button four times within two seconds; to produce a ‘+', press the * button twice within two seconds.
You should now get a message saying ‘phone restriction off' (or words to that effect). You only have five attempts to enter the correct code so be extremely careful. If none are successful, the phone will still work, but you'll have to go to the network or a retailer to get it unlocked instead.
Method 2. Buy a codeIf you haven't found a free code, it may be possible to buy one. Obviously the aim here is to find the code as cheaply as possible and it's only worth doing if the reason you're going to unlock your phone will save you more than the cost.Who is this for?
This applies to most modern handsets, so it's always worth trying, but if it doesn't work then there's still a chance using Method 3.
  • First, get a quote from your network.
    Phone your current network and ask it how much it'll charge for an unlock code. Unfortunately, networks tend to play fast and loose with their unlocking fees, to the extent it often seems they're making them up as they go along. You may be quoted anything between £20 and £120, depending on your handset, network, and it seems, which way the wind is blowing that day.
    Vodafone is the only exceptions from all this cloak-and-dagger pricing; its contract customers can get phone unlock codes for free regardless of how far into the contract they are, and so can Pay As You Go customers provided they've been with the network for at least 12 months. If not, a reasonable flat-rate £19.99 is payable.
    Important note: If your network cannot quote you a price for an unlock code, then the chances are your phone isn't unlockable by code (they should tell you this if asked). If that's the case, don't bother looking at other sites that sell codes, they may charge you just to tell you it isn't possible. Go straight to method 3 instead.
  • Then, try the dedicated unlockers.
    Having got a benchmark unlocking price from your network, you can hit the web and the high st. to see if they'll beat it. If looking online, be sure you know exactly what you're getting before you pay; read the terms and conditions to make sure they won't fob you off with something other than the code you need. Also, always check the legitimacy of sites; there are some dodgy operators working in this business.
    Whilst the web's probably not the best place to look, it's likely there are businesses offering mobile unlocking on your local high street. Check phone shops, markets and even some newsagents and key-cutters; they might be cheaper. The added advantage of these is that if they can't do the job you won't be charged, whereas on the web you may pay regardless.
    It can take anything between 15 minutes and a week for your code to come through, depending on the network. Once it arrives, follow the instructions in method 1 to put it into the handset.
Hope I helped Dr Reed - Unlock expert
Posted on Apr 05, 2010
Unlock Nokia
Get the Unlock code for NOKIA N95 Model at here
Theunlockspot.com/supported-phones/rs10wp7/ and Unlock Your NOKIA N95.
Dec 13, 2011 | Nokia N95 Cellular Phone
Unlocking code for nokia n95
we have already direct unlock in n95 and no need unlocking code cause unlocking code is expensive conpare direct unlock try to keep in touch with me truth my ym : andy_lecnah@yahoo.com
Jul 11, 2009 | Nokia N95 Cellular Phone
N95 unlocking codes
i need an unlock code for a nokia N95
Dec 15, 2008 | Nokia N95 Cellular Phone
Code to unlock nokia n95
buy a no cut unlock sim for 3.99 of ebay.I got one they are brilliant.Also they are a great posing gadget as they unlock 1500 phones
Nov 27, 2008 | Nokia N95 Cellular Phone
Nokia n95 unlock
I need unlock code for my nokia n95. He is france orange. Hes emai nummber is. 353094022648535. Thank you wery mutch. my e-mail is : pekarp@maffia.hu
Oct 21, 2008 | Nokia N95 Cellular Phone
Unlocking N95 8GB
The phone needs to be unlock and pls remember unlocking is not a free service. So you can try online at www.unlockitnow.com , www.mobile2mobile.net or take it to a mobile service center that unlock phones.
Jun 13, 2008 | Nokia N95 Cellular Phone
Nokia N95 GB unlock code
hi,friend i need a unlock code for Nokia N95 8GB for which IMEI:355255016136320  pl. kindly help me
May 28, 2008 | Nokia N95 Cellular Phone
Unlock nokia n95 8gb
landybaby - take the phone to your mobile provider and have them fix the phone issue for you.
Sumitchy - to ahve the phone unlock you need to try mobile2mobile.net or take it to be unlock via testpoints.
May 27, 2008 | Nokia N95 Cellular Phone
Need unlocking code for Nokia N95 8GB
i have a nokia n95 8GB and i only need a unlock code for it to unlock my phone
Apr 14, 2008 | Cell Phones
Unlock codes?
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
I also need to know the network that the phone is locked on, and the country the network is from. Then I will give you the codes.
Mar 11, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
387 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
