Question about HP LaserJet 2840 All-In-One Printer
My HP 2840 reads replace the supply using black only
I have replaced the black print cartridge and the warning light will not go away. Also, I cannot get the printer to print in color.
  • Anonymous Apr 28, 2009
    mine is with the yellow toner and it will not do anything else.
SOURCE: HP 2840
the carousel gears are out of sync - "off a tooth" and have to be realigned.  i spent 3 days last week fixing this problem - it's quite a job, to say the least.  my question - if you ever check for this answer - is: what were the circumstances when the problem first occurred?  just after replacing a toner cartridge?  if so, was it recycled cartridge?
Posted on Oct 25, 2007
mdsaeed67
  • 849 Answers
SOURCE: HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Posted on Oct 28, 2008
leroyal
  • 2120 Answers
SOURCE: HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Posted on Jan 13, 2009
SOURCE: Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Posted on Oct 23, 2009
SOURCE: 2840 only prints on right side
If you are a bit adventurous and a bit patient, you perhaps can fix this yourself, and not require any disassembling. It worked for me on a similar 'carousel' unit... hp2550L.
For extra info, check this post out. http://www . fixyourownprinter . com/forums/laser/40284 (remove spaces)
If you look closely at the spot where a toner cartridge slips into a slot of sorts, you might see left side aligned and right side just a little off of 'good alignment' for that slot. What I did is to pull on the top of the black-plastic gear. Pull it toward the center of the printer.
There is a small, white gear at the very top of the black gear (not easy to see at first). By this pulling and bending of the black-plastic gear, you can get the gear teeth free of the white gear --- for just a moment. Just enough for the gear teeth to free-up and find their proper place. It doesn't take much.
When done, take a breadth and relax. Turn power off/on, and try it out.
Posted on Jun 08, 2010
Hi there , I have a HP 2840 Color Laser Printer that is saying "Replace Supplies " . All cartridges are showing "empty" besides yellow . I only wish to replace the black cartridge and...
There is no option like what you are expecting. But now a days all chips are avil in market simply replace the chip & cut the cost...
Sep 12, 2011 | HP LaserJet 2840 Printer
My printer won't print---I just had the black ink cartridege refilled but it keeps saying replace supplies
Return the cartridge and use only genuine supplies with HP. HP cartridges have chips on them that dictate if they are OEM or not. Typically, if you use a refiller , these chips won't get reset.
Oct 20, 2010 | HP LaserJet 2840 Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
Sep 23, 2009 | HP LaserJet 2840 Printer
HP 2840 *(Error Message) = replace supply using black only Will only print in black All color and black toner are 75% or more full The drum was low so I replaced it just in case but error message remains.
By repalce supplies, it means that you have to replace the other toner cartridges and that it is only going to print black only
Al
Eliteprintersolutions@gmail.com
Apr 14, 2009 | HP LaserJet 2840 Printer
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
DRUM Q3964A FOR HP 2840
10.000x Supply error Description E-label can’t be read or print cartridge is not properly installed. Solution
  1. Reinstall print cartridge.
  2. Power cycle device.
  3. If the problem is not solved, replace the cartridge. NOTE: The software CD-ROM that came with the HP Color LaserJet 2820/2830/2840 all-one includes an animated tutorial that shows how to replace the print cartridges.
    1. Remove any media from the ADF, and then push the scanner-release button to open the scanner assembly.
    2. Open the cartridge door.
    3. Make sure that the correct print-cartridge slot is in the access position.
      • If the correct print-cartridge slot is not in the access position, close the top cover and the scanner assembly, and then press ROTATE CAROUSEL until the correct print-cartridge slot is in the correct position. Pinch together the two large blue tabs on the first cartridge, and then lift the cartridge straight up to remove it from the carousel.
    4. Remove the new print cartridge from its packaging, remove the orange cover from the print cartridge, and then pull the orange tab straight out to remove the sealing tape.
    5. Squeeze the blue release levers on the print cartridge, holding it with the roller facing you. Lower the cartridge straight down into the carousel until it is firmly in place.
      • To replace another cartridge, close the top cover and the scanner assembly, press ROTATE CAROUSEL , and then repeat the previous steps. NOTE: If a black print cartridge was replaced, then the device prompts to have a cleaning page ran, unless the device page count is less than 100 pages.
    6. Close the top cover, and then close the scanner assembly.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00414128
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | HP LaserJet 2840 All-In-One Printer
Hp 2840 "Replace supplies"
If one of the color cartridges runs out the machine will switch to black only mode. However, I have found no way to force it to continue printing in color mode when any one of the cartridges runs out.
Apr 26, 2008 | HP LaserJet 2840 Printer
REPLACE SUPPLIES
Make sure all cartridge are install and secured into place...(take all the cartridge out and back in ) close front door cover and it will go into cartridge calibration...If not, press the "menu" key and with the arrow go to print quality and confirm with the enter key. Go to calibration and confirm...
Let me know....
Mar 26, 2008 | HP LaserJet 2840 Printer
Replace Cathridge
The front panel tells you witch toner cartridge should you replace. If a supply memory error ocures then the cartridge should be replaced or exchanged with a new one. The imaging drum unit is also consumable. for "Joe 50" - there are 4 toner cartridges in the printer.
Dec 28, 2007 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
