Question about Samsung HC-R4755W 47" HDTV
Samsung HC-R4755W turns on and off by itself.
After about 5 min. somedays and 4 or 5 hours others the TV will turn itself off and back on constantly. A tech suggested a new power supply. Not sure. Help.
  • hvacman81 Apr 29, 2009
    my tv turns off about evert 15 minutes and sometimes more. Now there is a reddish pinkish line down the middle and a greenish bluish line. Looks like someone colored on it. It is only 3 years old. Any answers
    Genius:
  • 1,112 Answers
Have Capacitors checked in the power relay circuit, also if you have young children who like to push the buttons on the front of the set make sure none of the buttons are sticking inward or stuck in a pushed in posistion. More then likely it might be caused by a faulty System control board which we call the signal board, or bad connections on the power supply, Have a tech check the connections on the Flyback transformer and the High Voltage Deflection Area on the HV Power supply. I believe you have Cold Solder Joints in the HV Power Supply.
Hope you this helps you..
Posted on Sep 21, 2009
How do I remove the outer case, shell, on a Samsung hc-r4755w projection TV? Need to get to the back of the screen to clean it, cat puked down front of TV and got behind screen
there are two screens back to back and I think if you look from back with rear cover removed you will find the debris is between them.
Not going to be easy or simple to deal with.
Oct 25, 2012 | Televison & Video
Our Samsung tv will not turn on/power on. It sounds like it starts to power on, the light blinks twice then you hear something, the light stays on solid after that. This model usually has an audible tone...
I would suggest two things you need to examine :
First remove and examine the lamp to make sure it is not shattered or fractured.
Second examine the color wheel that faces the lamp (see attached photo) and if you had a fan like sound or high pitched whine before that points to the color wheel.
The color wheel is a do it your self replacement (I can help) and takes less than a hour.
Let me know what you have tried and if the lamp or color wheel are intact.
SD TECH
Sep 16, 2011 | Samsung HC-R4755W 47" HDTV
My tv wont turn on and we just had a huge thunderstorm
It is possible that the power surge locked up the processor and if you unplug it from the wall for 40Min, it will reset back to normal, and if the TV still don't come on then it probably did damage to the power supply and would have to be replaced.
Jul 11, 2011 | Samsung HC-R4755W 47" HDTV
Samsung 56in big screen lights flashing-cuts off
theres defective caps in the power supply
Apr 25, 2010 | Samsung Televison & Video
Tv switches off after 5 mins
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
May 09, 2009 | Televison & Video
TV won't turn on or stay on?
no solution, Did Samsung get me for 999.00 plus tax?
Mar 30, 2008 | Samsung HC-R4755W 47" HDTV
Flickering Screen
soon the picture going to go to black screen, you got somes capacitors bothering, you better to call a tech now that he can see the problem, later will cost you more..good luck ps the picture many times tell to the tech whats going on.
Aug 07, 2006 | Samsung HC-R4755W 47" HDTV
Samsung HC-R4755W 47" HDTV Logo
227 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
