Question about Dell W2607C Television
Pixel Problems I just set up this TV, and I notice the pixels are very visible. It makes the picture quality very poor, I have read the owners manual and I cannot find anything to fix this. Anyone know a way to fix?
Yes, first of all are you watching digital or HD. Because in digital you will get pixels visible cos its not coming from a HD source. Secondly if the pixels are really really big, then the TVs just crap.
Posted on Dec 20, 2007
Hi there I just bought a Polaroid two instant print camera but the quality of pics is really poor very washed out and even a bit blurry do I need to set it up?
set your pixel ratio to the largest setting, this means less pictures per memory, but higher picture quality. Also if possible adjust your iso to the highest setting, as well as the shutter speed, having both of these settings set to the highest point will require more light for picture taking, however will result in the highest quality image.
May 05, 2011 | Polaroid Cameras
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
I have a problem with the picture on my Infocus IN1501. It has small squares on it and I see every pixel. How do I remove this?
Generally the screen is full of pixels, and thats a good thing.
It's a problem when you see the pixels that should be off, and don't see them when they should be visible.
So I presume that your pixel problem may be the first type where they appear when they should be hidden.
Now it would be good to know if the bad pixels are all one colour, or if you have chromatic pixelation problems.
Monochrome pixel problems are better than chromatic pixel problems. But alas all pixel problems come back to the DMD or the colour wheel.
Either way your machine is basically compost material for the garbage shredder, unless you want to pay big money to replace the faulty bits.
Ask the local serviceman or servicewoman to give you a quote to look inside the unit and see where the pixels have gone astray.
Mar 17, 2011 | InFocus IN1501 DLP Projector 3000 Lumens...
I WANT TO SEND 11 PAGES OF A DOCUMENT BY EMAIL HOW CAN I MAKE IT SMALLER
Turn down the picture quality and it will require less memory
Example 10 mega pixel camera
change it from 10 Mega pixel to 5 mega pixel
Mar 07, 2010 | Fuji FinePix 2600 Zoom Digital Camera
Pictures taken from sony digital camera (6 Mega pixel) are not clearly seen on SONY DVP FX720. Is there any settings we need to do to get good quality?
change the format eg 640 x 480 to a higher resolution ...a good quality uses about 250kb per picture most jpegs use 50kb to save space
a really good picture can use 500kb.
May 15, 2009 | Sony DVP-FX720 Portable DVD Player
Pixelated lcd tv picture
it indicates that the problem is aspect ratio or pixel settings for thescreen
bring up the on screen menu and adjust the pixel setting to fit the screen or the apsect ratio to fit the screen
read the operators manual to see how the adjustments are made
May 19, 2017 | Sylvania LC370SL8 37 in. LCD Television
Pixel problem, all pictures taken have poor pixel resolution
It sounds like you set the file settings to a small file size - perhaps in order to get more photos on a single memory card. You need to change the setting to the largest file size possible, at the highest quality. The steps for this will be in your manual. If you need detailed instructions and don't have your manual, let me know and I'll lookup your manual online.
Dec 30, 2008 | Olympus Stylus 600 Digital Camera
BAD PICTURE QUALITY
jagged pictures indicates pixel incorrect
get the screen menu up and adjust the pixel settings
Dec 27, 2017 | Samsung DVD-HD960 DVD Player
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Jan 28, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
204 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
