My panasonic plasma th50pz800A decided to shut down whilst switched on, was not in the room at the time to see what happened.I reset the powerboard to the tele now it will not show picture or sound green power light goes on turns red and flashes and have noticed large fault/crack in the centre of the panel behind the glass
  • smhawthor273 Apr 21, 2009
    Hi Taran,
    Thankyou for your reply, additional info tele is less than 6 months old do you think
    warranty would cover this?? also I was using a surge protect cut out powerboard so how could this happen??
  • smhawthor273 Apr 27, 2009
    Have phoned panasonic support and have had no assistance as yet, they asked for the fault code (how many times red light flashed)through the power button blinking, it was seven times does anyone know what that error code is referring to.
    Novelist:
  • 166 Answers
I'm sad for you and wanna inform you that your picture tube is gone due to powerboard circuit failure.
These board get power from SMPS and they are temperature dependent. So, 7 times blinking indicates power transformer failure. In that condition you need to follow the following procedure :
First, unscrew the back panel of the tv console (should be a bunch of 1/4" hex head screws). There will then be a large white panel at a 45 degree angle held in place by two tabs or maybe even screws. Remove it to see the CRTs. A quick check for the blurry problem is to look directly into the CRTs while the tv is off. DO NOT do it while they are on if you can help it, as it is not good for your eyes.
Shine a white LED flashlight down into each of the CRT's top lenses. Avoid classic incandescent light in this case, since you will be looking for the difference between white and yellow. I you see a white plate inside, good. If the inside looks yellow, and has floating things in it, then the coolant fluid inside is old and bad. You can replace this, but it is a VERY delicate task and MUST be done in certain steps to avoid ruining the electronic boards anywhere within splash zone or drip reach of the lens couplers. The coolant is a special blend available at most tv repair shops, but it's basically clear antifreeze (which you wont likely find in an automotive store).
For the color being off, it is most likely the gain on each CRT being out of whack. First, change all of the user settings (in the on screen menu) for image, color, sharpness, etc to the middle or default.
With the back panel off, somewhere near the bottom of the inside there will be a small black plastic box with wires coming out the sides. This box should have 6 knobs on the front of it (the face facing the rear of the tv); 2 rows of red, green, and blue knobs. These are the screen controls for FOCUS and GAIN. And they should already have some sort of label telling you so.
I placed a mirror in front of my tv so I could see the screen as I adjusted, but you might be able to see it somewhat by hanging a sheet over the front of the screen and looking at it from the inside.
There's a much more in depth method to do this that is described in the service manual (which you are likely to have seen by now; they are usually either stapled to the back of the tv or hanging somewhere inside and easy to see)
But basically, just turn the knobs gently around until the picture looks about right to you. (Remember, if you turn them all up super bright, the CRT will not last very long. Try to keep the knobs near the middle of their turn ability)
If you want to do a full out overhaul of the screen, you'll have to make a lot of adjustments with a bunch of little knobs (variable resistors, really) on the computer board inside. The service manual will tell you what each one corresponds to, but most of them will have a subtle label on the board.
Rate the solution if it was really helpful to you.
Have a nice day!
With Regards,
Shyny
Posted on Apr 27, 2009
  • 10,515 Answers
Hi Smhawthor273,
Regarding the problems you have with your plasma is vey rare......
No sound No picture - Usually power supply, might be an issue with powerfly or Horizontal Output Transistor....
Crack - Is that behind the LCD Screen? If yes, there might be a short circuit and that might have cause this. Now, there might be millions of connect millons and it might have affected any of the connections.
If that's a combination of power supply board / any other board and a crack - It would cost your pocket any way between 300-500 bucks. Even if you decide to Do It Yourself, It would cost you more than 300 bucks.
Is that really worth investing? That investmet wouldn't gauarantee a permanent fix and you would agree.
Now, the best bet would be to call a local tech and pay 45 bucks to check whether he could do anything.
Note - Rare would be the case there is only short circuit.
As far i believe, you have lost the plasma. Spending so many bucks on a dead plasma seems absurd.You can also check.Take a Voltmeter and check the continuity.
I hope my solution would have helped you to fix this,
Even still, you want to Fix, let me know so that i would be able to provide you with cost effective service manual.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 21, 2009
  • taran_2005
    taran_2005 Apr 21, 2009
    I am dead sure it would be in warranty. All electronic items are usually have a warranty for one year and usually this includes in warranty.
    That might be one of the reasons for short circuit.Might be a wrong selection of surge might not handles the voltage easily and that might have caused a short circuit.
    However, we cannot jump on this conclusion without looking at the plasma.
    I would advise you to call panasonic support as this is only 6 months old. You are aware that this is a short circuit.This would able to have a better assistance from them.
    Let me also inform you as this is under warranty, even if they would charge for parts, i guess it would be less than 100-150 bucks depending on the fault. If that's a minor one, they would repair it without any cost.
Free tv troubleshooting
probably needs one or both of the sustain boards, i would invest a little money and have a professional check and diagnose it, I feel this presents to big a problem for the layman.
Jun 20, 2013 | Panasonic Televison & Video
Panasonic
For that to happen you may have an electrical phase problem.
Maybe you just overload
When that happens will blow the fuses or the power supply.
Replace the power supply Module
Nov 01, 2012 | Panasonic TC-P50XT50 50" Class Smart TV...
I have a panasonic plasma tv. Model #
I don't know but I'm having a similar problem. I have a plasma
TH-50PZ77U. It will run for a while and then shuts off. Also, the volume goes up and up and then it shuts off at times. Like I have a ghost here. I had both of my sat. recievers replaced. It seems to get worse over time with shut down. I called panasonic and they had no info and denied this was an issue but I beg to differ from my research here online. It's only a few years and we paid lots of $$$. They gave me a # for service 1 hour away!
Jun 20, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic yh42pa20 shut down issue
there are a number of parts that may cause your problem power supply, z or y sustain boards, drive boards or panel. needs a qualified servicer to check out.
Jan 23, 2009 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
No sound from my plasma
This happened to me today on a 42 inch Panasonic Plasma... Just shut off suddenly. Turns out is was my cable box - I reset my digital cable box (unplugged and restarted) - then the sound was back on.
Dec 29, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My panasonic 42 plasma won't switch on red led light flashes 10 times then pauses before flashing again 10 times and so on
I would say you have problem with pboard or PA board
(10 blinks means unit shuts down becuase in tuner section there is short)It will happen if there is no 15V available from power supply
Good Luck
Dals123.
Oct 09, 2008 | Televison & Video
42" panasonic viesta plasma tv cuts off after about 30 minutes
Hello gws51,
This sounds like a shutdown circuit proble, which is caused by the draw of excessive current. I would suggest that you have a qualified TV repair person look at you set and repair it.
I hope this helps
Thank you,
Shuttle83
Jul 16, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Oct 30, 2007 | Sony KLV-S23A10 23 in. LCD HDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
