Question about Dometic Rooftop RV Air Conditioner
Compresser continues to run after the fan kicks off
The unit reaches the set temp and the fan stops but the compresser continues to operate (i hear a loud humming sound)
    Novelist:
  • 189 Answers
Turn the unit off before you damage your compressor. You probably have a contactor that is stuck in the closed position. You will need a new contactor. Be carefull if you try to replace it yourself. You will be dealing with both high and low voltage. If you wire it wrong you could damage the a/c or more importantantly you could hurt yourself.........
Posted on Apr 24, 2009
When I turn my window unit on, it will cool for 2 - 3 minutes. Then the fan turns off and the compressor continues to run for maybe another 90 seconds, then shuts off.
Make sure the filters are clean. Check what mode it is on as well. On heating, it is normal for there to be a delay before the unit starts up and then "run on" when turned off. Also check what temperature is set on it. If the temp is too high, the machine will cycle on and off as it thinks it has already reached the temp you want.
May 25, 2015 | Heating & Cooling
Should the heat pump stop when it reaches temp?
Check to see if you have fan on automatic or continuous run ,it should have a setting so you can get air flow at all times or just when unit runs
May 18, 2015 | Mitsubishi Heating & Cooling
Why is the AC still running after the set temp has been reached?
You may be hearing the fan run. Normally the fan will run 30-90 seconds after the unit has reached temperature to give you the air that you just paid to condition.
If it is actually the a/c running, that is because the thermostat internally reads in tenths of a degree. So when you set it to say 70 degrees, it is really set to 70.0 degrees. The thermostat will show 70 degrees when it reaches 70.5 degrees and continue to run all the way to 70.0 degrees
Welcome To the Best HVAC
Oct 10, 2014 | Heating & Cooling
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Furnace blower fan problem
Hi check out the fan control switch could be dirty itsounds like this is nit cutting to let fan run also check setting fan off fan on , temp rise and fall
Feb 06, 2010 | Heating & Cooling
LG 24000btu not blowing cold air. Fan runs but i do not hear the compressor kick on. temps upstairs hit 104 and temp is set at 80. unit is only in use for 2 months. none stop though on cool.
please check the temperature sensor this will make the compressor for running and stopping and also check the compressor if its in warranty period please call the service technician to check these and replace if necessary.
Sep 04, 2009 | LG Electronic Window Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
136 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
