Question about Abit AB9 Pro Motherboard
Badly flashed bios
Hello, I am desparate because I literally destroyed my motherboard in an attempt to upgrade the bios. The flashing process stopped somewhere in the middle and now it won't start at all. Although it powers on, that's just about all it does and I found myself looking at a BLACK screen of death. I own(owned) an AB9 pro motherboard and I would be overjoyed if you came up with a solution other than having to replace it or the bios chip or whatever. Thanks in advance
    Sergeant:
    Champion:
  • 293 Answers
I can fix that if only you are in my country(Philippines)
Posted on Sep 22, 2007
SOURCE:
MotherBoard: Hewlett-Packard 080Ch Serial Number: SGH31601C5 Bus Clock: 533 megahertz
any prescott/netburst based xeon- basically, any xeon before the advent of the core2 archetecture.
depending on your motherboard's voltages, the fastest upgrade you can count on would be to a 3.2ghz chip with a notably larger cpu cache.
you could check with hp support for any bios updates to allow for newer chips; however, even if available, bios "flashes" completely destroy the motherboard if the smallest glitch occurred during the process
Aug 27, 2014 | Computers & Internet
P4p800 se-uayz
Hello you can find drivers and the manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P4P800%20SE&p=1&s=15
You just have to select your windows system.
Any file from here needs to be unziped, before you install the driver.
When upgrading the bios you have to make sure, its the right mainboard bios file.
Open the case and look for the mainboard number.
Flashing the bios with a wrong one, will destroy the mainboard !!!!
Good luck
Mar 26, 2013 | Intel ASUS P4P800 SE-UAYZ 800FSB P4...
Sata connectors on mainboard don't work
Hello you can download the manual, and the drivers here:
http://www.asus.com/Motherboard/P5S800VM/#support_Download
By selecting your windows system.
Open the manual folder, and click global for download.
You will need adobe reader, to read the content.
You have to setup the bios, so it can see the drive.
A bios upgrade, should solve the problem, but you probably have to use the old ide drive to do so.
Warning !!! flashing the bios with a wrong one, will destroy the mainboard.
If you are in doubt to do so, let a expert do this job for you.
Good luck
Jan 21, 2013 | ASUS Computers & Internet
Sata connection
Hello you can download the manual here:
Good luck
Jan 21, 2013 | ASUS P5S800-VM Motherboard
I can't my bios update.
Hello visit the homepage here:
http://www.supermicro.com/products/motherboard/xeon1333/5000x/x7dal-e.cfm
For downloading the manual.
You will probably need adobe reader, to read the content.
Here is how you upgrade the bios:
http://www.supermicro.com/support/resources/results.aspx
Remember flashing the bios with a wrong one, WILL destroy the mainboard !!!!!!
Good luck
Jan 18, 2013 | SuperMicro X7DAL-E Motherboard
I need m2n68-am bios bin file
Hello download here at asus:
http://www.asus.com/support/Search-Result/?keyword=m2n68-am
Select download and your windows system.
Open the bios file folder.
Click on global for download.
Unzip the file.
Make also sure it`s the right mainboard, because flashing the bios with a wrong one, WILL destroy the mainboard.
Use the asus update utility, to upgrade the bios, while windows is running, for a safe upgrade.
Good luck
Jan 15, 2013 | ASUS Computers & Internet
Phoenixbios d686 for 017578387 1998
Hello visit the mainboards home page, for download of the bios file.
Flashing the bios with a wrong one, WILL destroy the mainboard.
And don`t upgrade the bios when the system is running fine.
Good luck
Jan 11, 2013 | Shuttle AB45 (SHUTAB45) Motherboard
Our computer is telling us we need to update the BIOS computer shuts itself off
All BIOS components are serviceable via a firmware upgrade that is known as "flashing" this process is called "updating the BIOS". The process itself is fragile since any power fluctuation during a flash may irrevocably corrupt a BIOS' firmware. Great care will need to be taken in order to safely accomplish this.
This guide will help you flash your BIOS by taking precautions and walking you through each step. Not all computers will have the same BIOS manufacturer, let alone the same process, but many have similar steps and precautions.
Guide: http://www.wikihow.com/Update-Your-Computer%27s-BIOS
Also check with your motherboard manufacturers website for specific BIOS updates and updating instructions. mpawlak908
Oct 18, 2009 | Intel Computers & Internet
Bad bios flash
Hopefully you save a backup copy of the bios before you did the upgrade. If you did then start the upgrade process again and select the original backup copy as the bios file to upgrade. This will put you back where you were before the upgrade.
May 26, 2009 | Intel Motherboard
Motherboard BIOS softwere for update
The process of upgrading the BIOS on a computer is also
called "FLASHING" the BIOS.
On very old computers (486 and older) the BIOS may be
permanently programmed into read-only memory chips,
which are not flash-able, although it may be possible to
replace the chips, or re-program them using special
equipment by a qualified technician.
On virtual all modern computers, the BIOS can be updated
using new data and a special FLASH program available via
download from the manufacturer.
This is a very dangerous procedure that can destroy the
motherboard if performed incorrectly, and should not be
performed unless absolutely necessary, such as when
you computer or software will not run properly without it.
Most mother board manufacturer's (for example Asus) offer
software patches and downloads on their web site, as well
as BIOS upgrades.
Note that the BIOS is 100% board specific, installing the wrong
BIOS can permanently destroy *********** board, so make sure
that you download the correct one for your board.
Once you have the downloaded the BIOS upgrade, there are 3
possibilities:
1) The downloaded file is self-installing, either from Windows,
or it creates a boot-able diskette, which in turn contains all
the files needed to update (FLASH) the BIOS.
2) The BIOS comes with a a separate installer (.exe) which
either runs from Windows or via a boot-able diskette.
3) The existing BIOS has a "built-in" flash utility, accessable
through the BIOS settings. This utility runs at a very low
level without any operating system to self-update the BIOS
from your download binary file, located on the hard drive or
on a diskette.
This is by far the best and safest way to do the job, but only
if your motherboard and (existing BIOS) has that capability.
In any event, the first step is to visit the manufacturer's WEB
site, then go to SUPPORT or DOWNLOADS.
Find the exact model and version number of you motherboard
in the manufacturer's list, and download the latest BIOS
update, and any installation (or flashing) utilities that come
with it.
1) Follow the manufacturer's instruction exactly !!!!
2) Do not turn off the computer until the BIOS update is
complete, and you are instructed to do so !!!
N.B.
The computer BIOS is the lowest level program on your PC,
without which the computer CANNOT read the disk drives or
perform the lowest necessary functions.
If the BIOS is damaged, or
If the wrong upgrade is installed, or
If the upgrade is performed incorrectly, or
If the upgrade is interrupted or crashes before finishing,
the computer may become unable to repair itself, and
the mother-board may become permanently unusable.
(This depends on the actual mother-board and BIOS design,
and on the damage done by the failed installation)
Good luck,
Please rate my answers,
Martin
Aug 04, 2008 | ASUS P5L-MX Motherboard
Abit AB9 Pro Motherboard Logo
384 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
