Question about Toshiba Satellite A75-S211 Notebook
Wont charge while powered on or run on ac power
Strange thing is happening. This laptop will only run on battery power. I tried powering it fron the wall with the battery out and it will run for a few seconds then shut down. When the unit has a battery and pluged in, it will light up the charge light then when you turn it on the charge light will turn off and run on battery only. If you plug it in while running it will show the charge light and switch to ac power profile, then it will switch back over to battery.
  • 39 Answers
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Posted on Apr 21, 2009
Acer Ferrari ONE 200 wont power up
you have to check that your battery is charging or not in your laptop by another laptop or battery,if problem is not solved,then check battery port
Dec 02, 2013 | Acer Ferrari ONE 200-1799 Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Charging it doesnt want to charge the battery and wont run off ac power . the battery is bad but it still wont run on ac power
Laptops must have a good battery in order to operate. If you take a good laptop, and remove the battery but leave it plugged in to AC it will not run.. Go out and get a new battery and you should be fine.
Aug 11, 2009 | Computers & Internet
Strange ac cord/power issues
Hello my friend, Try to check your battery if the is it working normal cause sometimes the battery itself has the problem its either lost contact or the battery is not charging or not normal. also try to see if the the the sensor or that links the battery to the software which is responsible to the update of charging energy is functioning normal but this is a rare possibility try to focus on the battery or the connector or power cord.
Hope this will able to help solve you problem. If you need more assistance just reply to this post. Thank you
Jonas
Apr 20, 2009 | Toshiba Satellite P15-S420 Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
Battery or charger ?
well...this one is interesting, for certain. You bought a display model, so the chances of it working off battery are mighty slim. Could be that the m/b was running off ac power all the time, and can NOT charge a battery. I'd take it back, and have them show you that it will run on battery, which is considered a fairly important issue with laptops, at least around these parts on Hawaii
Feb 06, 2008 | Acer Aspire 3680 Laptop
Laptop wont run on battery!
ok it looks like your battery has run out of power thats why it would not run when ac is off.If it so happens that the laptop runs when battery is connected to ac then battery seems fine by me just flat. Conenect them to ac and run your pc,go to your control panell and power saving options and set to mimimum usage/power saving mode in this way you charge your battery.Remember bright screen consumes more power
Apr 24, 2007 | Acer Aspire 5670 Notebook
Toshiba Satellite A75-S211 Notebook Logo
182 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
