Ever since I downloaded Smiley Central (which I have now uninstalled and deleted from computer) my monitor likes to turn light blue on it's own and for no reason imparticular and it is driving me madd!! I have McAfee and am updated and scan my comp regularly - blah, blah, blah. It has discovered no problems. My comp is a Gateway, Microsoft Windows XP Media Center Edition Version 2002 Service Pack 2, with flat screen monitor - was brand new.
-   I have a Gateway, Microsoft Vista program. My monitor changes colors, sometimes multi-colors of pink blue, grey, yellow etc. Also my screen saver (I use my pictures) does not always show the pictures in color; sometimes in black and white and sometimes multiple pictures show up on the screen. -   lorrozzell
Mar 14, 2009
-   I also have Microsof Windows XP Media Center Edition 2005. My computer monitor is fine, until I start recording or watching with Media Center. The screen will be fine for about a minute, then it will haze up in pink and blue colors. When I reboot, system is fine. I've replaced video card and problem still exists. It only does this when I'm using Media Center. I think this started happening after upgrading to Service Pack 3 XP.-   prefer2flyhi
Mar 07, 2009
-   exact same problem except when this happens it is eventually followed by the system freezing ..I can only then get out by manually restarting-   Guest
Aug 22, 2008
-   my monitor likes to turn light blue on it's own and for no reason imparticular and it is driving me madd!!-   jewan52
Aug 08, 2008
-   My monitor is changing colors started when I updated my window media player. What can I do to fix thi-   fmwwriter31
I doubt if this is related to the software you installed. Check the video lead that runs from the PC to the monitor. Sometimes the insulation becomes damaged or the wires break. With the computer on gently wiggle the lead around at one end or the other while watching the monitor, if the colour flickers then you have found the location of the fault. Also check the plugs are in firmly.
every time u see monitor become purple colour, shake the monitor and try to knock the left bottom corner of it. not use ur hand or things to knock, is grab the monitor and knock other thick.
hi, i have just tried to turn my computer on, the mouse and button on the tower are flashing, and...
(More)
hi, i have just tried to turn my computer on, the mouse and button on the tower are flashing, and the screen is changing to different colors, other than that it is unresponsive, please help
The black background of my screen is green, some white parts are pink and the text is fuzzy. When it...
(More)
The black background of my screen is green, some white parts are pink and the text is fuzzy. When it happened this summer, I attributed it to humidity or being on for too many hours. Please tell me what I can do? Thanks! Marilyn
I have some mild pink static on my lcd screen that changes as the contrast changes. the pc is a hp...
(More)
I have some mild pink static on my lcd screen that changes as the contrast changes. the pc is a hp compaq presario 6000. I have tried changing the dvi wire, turned off the system, all the monitor settings, unpluging the graphics card (a 512 mb nividea card) and reattaching it, but the only thing that effects it is the changing of the contrast.
