Uplink Probelm main uplink for network 192.168.1.0 has failed preventing network users to reach network 192.168.2.0. What Shall I do
  • 3 more comments
  • Ed Miller
    Ed Miller May 11, 2010
    1st go to command prompt and see if you have any connectivity type: ipconfig /all 2nd at command prompt ping both addresses you listed type: ping 192.168.1.0 (example) 3rd try typing: tracert 192.168.1.0 The tracert will tell you where you are dropping you signal or rather you packets. If all else fails type: ipconfig /release Next try ipconfig /renew That will reconnect your connection.
  • Herminio Halili, Jr.
    Herminio Halili, Jr. May 11, 2010
    ip address for lot of network router is 192.168.1.1 from the manufacturer. IT or the network administrator can change the ip address. Printer and computer is have two ways of assigning ip addresses by manually input the ip address or Dynamic Host Configuration Protocol ( DHCP ) give us the exact detail to you are trying to connect so we can help you.
    on what network you trying to connect? To other computer, printer, router, or to the internet. Ip address 192,168.2.0 will not tell me a clue to which you are trying to connect. get back to us with more detail.
  • Herbert Fields May 11, 2010
    can you please give me the make and model numbers for your routers. Also a basic overview of your network. I may be able to walk you through the setup.
  • Chris Hingee
    Chris Hingee May 11, 2010
    The IP address is not configured correctly.
    The IP address first number 0 is reserved and so is the last number 255. You can use any number in between but not 0 or 255.
    For your network users to be on the same Class C - LAN network and to communicate with each other, the first three group of numbers must be the same, only the last group of numbers are different and each PC must have a different number.
  • 55 Answers
Type: tracert 192.168.1.0
This will show you where you are losing your connection
Next type: ipconfig /release
Next type: ipconfig/renew
That will re-establish a connection.
Posted on Aug 02, 2009
How long distance can I get from 10GE optical SFP+ modules of Huawei X2CS?
Huawei MA5683T or Huawei MA5680T, Uplink board X2CS has 2*10GE optical module ports, the distance of SFP+ modules can reach 0.3KM, 10KM, 40KM, 80KM.
More related:
Huawei OLT
Huawei uplink board
Jun 21, 2017 | Huawei Computers & Internet
Why doesn't has uplink board for MA5608T?
MA5608T with compact design, there's no uplink board for it. The main control board MCUD/MCUD1 provides uplink ports? Huawei MA5608T OLT Access Network Thunder link com
Dec 05, 2016 | Computers & Internet
How do I turn my router into a wifi client?
most routers can\'t do wireless uplink and I find wireless uplink to, frankly, be poor anyway. you always here about "a copy of a copy not being as sharp as the original." (multiplicity) well its true with wireless as well.
you can however hardline that second router and have both routers broadcast the same network so that its like having one big network that is always fast all the way through.
(if you can find an acceptable way to run that wire)
here is what I did:
1)connect to your main router and check your IP (192.168.1.101 or something probably)
2)turn off your wireless and hardwire to your second router
3)set up the second router with the same SSID and password as the main router (important that its exactly the same)
3)on the main page where it shows your routers IP (the one you probably used to login to the router) change it to an unused IP that is easy to remember. (My main router is 192.168.1.1, my second is 192.168.1.2 and my third is 192.168.1.3)
***when you save changes the page won\'t reload because you need to reconnect to the new IP you just made***
4)now turn off the DHCP and save settings
OK... now its a wireless access point waiting to be attached to a router.
5)plug the internet wire into 1,2,3 or 4 but never plug anything into the uplink or internet port on the second router, that port is now unused.
You now have a network with two broadcast points that don\'t have any diminished speed or packet loss associated with wireless uplink.
May 21, 2012 | NetGear WGR614 Wireless Router
How to connect the network cable
you will have 8 ethernet ports in this switch... One port is for input all the other ports are for output...
If you dont have any dedicated uplink port, then any port can be used as an uplink port and other ports becomes downlink port...
The Lan slot of router should be connected to the uplink port in switch.... you can connect upto 7 computers in this switch(in downlink ports)...
Dec 13, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I FORGOT MY PASSWORD
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Sep 27, 2010 | Uplink Computers FS108 8 Port 10/100Mbps...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
How can I change my username & p/word back to theark19@aol.com from Wsab19@aol.com I don't know how I've managed to change it.
to change your user name control panel user accounts create an account or change an account
hope this helps
hope this helps
Aug 25, 2010 | Uplink Computers FS108 8 Port 10/100Mbps...
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Tutorials On How to configure a D-Link DES-1008D Ethernet Swich
There really isn't much to setting up an ethernet switch hub. Plug a network cable into your router LAN connection and into port 1 or uplink port of your switch. All other computers will attach to ports 2 to 8. If you have an Uplink port and port 1, they usually can only be used singlely. That is to say use either the Uplink or port 1 Using both disables the switch hub.
Jun 01, 2009 | D-Link Computers & Internet
Didn't recognize uplink
Not really, you just have a minor misconception. The network feed is not suppose to plug into the uplink. The uplink is for connecting 2 switches together so they act as if they were one switch.
Sep 22, 2008 | Linksys EtherFast 3116 Port 10/100...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
