Question about Philco PC-841.651 Turntable
The belt came off my Philco Record Player 841.651, we put it back on,but, now the music is dragging. Do I need a new belt and if so, where can I find one?
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: record player
does the plastic mat lift up? if so there should be a hole where it can be slipped back on , if it fell off more than likely you will need to replace it and the table should pop off by lifting it up.
Posted on Jan 28, 2008
Grubhead
  • 5484 Answers
SOURCE: Philco 841.205 Turntable Issues
I take it that it doesn't turn? OK two choices for you. Faulty motor, or a on/off switch that doesn't work. If you have to move the arm to start the turntable then some kind of leaver switch is either bent or broken.
I should imagine this model uses no more than a 12 volt motor. If you have no look with the switch, find the motor and take it out. Then stick a 9 volt battery on it, or lower voltage if it's only 6 volt motor. If it don't go it's bust!
Posted on Jun 04, 2010
STYLUSCITY
  • 271 Answers
SOURCE: the belt came off my record player how do i put it back on
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 285 1 7560000 10692000 359410 259 261 257 280 262 283 1 0M=D#_"(P_4>T8_8*@@.320 5 1 1 286 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 282 134217728 1 1 -9999996.000000 -9999996.000000 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird -87325200 -87325200 (`@````````` 267 263 5
To replace a drive belt.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Posted on Nov 20, 2011
The turntable started dragging and now the record won't finish because it stops. What's wrong ? do I need a new turntable motor? Everything else seem to be working fine thxs David
Is this a cd player or a turntable recordplayer ???
cd player that drags usually mean theres a misalignment in the tray that holds cd
turntables that drag unless they are direct drive usually need there rubber drive tires replaced or a belt what ever it has
Oct 23, 2015 | Audio Players & Recorders
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
My Philco 841205 Turntable spins but when i put
You need to replace the belt, make a note on how it fits before removing it.
THE RECORD DRAGS, THERE IS A SMALL BLACK BAND LYING INSIDE THE BOTTOM UNATTACHED WHERE DOES IT BELONG
thats the drive belt for the record [layer, it loops around the entire disc on the bottom plate and the small spindle that sticks up off the top of the motor drive
Jul 19, 2011 | Philco 841205 Turntable
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
what do you mean it drags? I noticed if you don't pull the arm back far enough,it will turn on,but the arm will drag foward scratching your record. Try pulling it bacl ALL the way and then it should give you no problems.
Sep 29, 2009 | Philco (R) Classic Turntable CD Shelf...
How to record music from my lap top to mp3
to record new music to mp3 from a cd just open up windows media player and insert your cd click on rip and there you go your new music should be added to your library there and after that you can sync it to your mp3 player with no problems
Sep 24, 2009 | Philips GOGEAR SA6045 MP3 Player
How to put songs in this gogear mp3 player?
Open Windows Media Player. Hit the "Rip" tab at the top and put in the CD(s) you want to record. You can put in as many as you have hard disk space for. Each one takes 3-5 minutes to "Rip". When you are through, you will need to plug in your player via the included usb cable. Let the computer "find" it. Then, you will go back to Media Player and hit the "Sync" tab at the top. When it comes up you will see a list of the all music you recorded. You can drag and drop music from the center column to the right column under where your device is listed. If you drag whole albums, whole albums will be transferred. Once you are done, hit the "sync" button at the bottom right and wait for the fireworks to end. The "syncing" process goes very quickly. Now play music!
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Streched CD drive belt
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
Jan 13, 2009 | Philco 841205 Turntable
My music wont transfer to my player
I have a few for you.
The music needs to be in mp3 format
I use a program called super sound recorder and it converts them to mp3 or wave.
once you record the music the new one you will need to rename on super.
and drop and drag into player.
You can do the same thing with a free program called. mp3 conversion tool. good luck.
Dec 28, 2008 | RCA M4204 MP3 Player
Philco PC-841.651 Turntable Logo
205 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
