Question about Sanyo DP32746 32 in. LCD Television
How to adjust brightness on an older model sanyo tv
There is no way to adjust the brightness on the remote menu. is there another way. It's an older model flat panel sanyo tv. about 5-6 years old
  • Jon Stockman May 11, 2010
    Are you using the original remote control? Some universal remotes won't work. Can you bring up the menu and control other functions? 1-800-877-5036 ext 1485 toll free numbers to purchase remote from sanyo. Have your model # located on the back of the tv ready when you call Most TV's use electronic controls no more knobs to twist. Hope this helps.
5 Suggested Answers
SOURCE: unlock Olevia remote control
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Posted on Jan 28, 2009
jerryg50
  • 1689 Answers
SOURCE: lost my remote control
You require the original factory remote to have the menus. The link below is the source of where you can order a remote.
http://us.sanyo.com/entertainment/remotes/
Jerry G.
Posted on May 17, 2008
SOURCE: i have a sanyo 32 inch flat screen television
you can order a replacement off of the website
Posted on Apr 04, 2009
  • 8457 Answers
SOURCE: I have no picture on my Sanyo Dp32746 LCD tv, the
U replaced the 1 or 2 LCD inverter long boards,still the same problems.Sorry,this is a rare problems,but it seem the Tuner board is the problems.Replaced the Tuner board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Posted on Oct 08, 2010
Why is my Sanyo tv so bright?
You need to adjust the TV brightness and contrast values?? Go into the main menu (on remote control) and find the video options.
Jun 26, 2017 | Sanyo Televison & Video
I have a Sanyo Flatscreen, the original remote was lost. Now when I turn on the TV the picture is to big to fit. HOW do I adjust it without the remote?
use the menu button on the side of the tv
that brings up the screen menu
using the channel and volume buttons move around until you find aspect ratio
find the one that fits the screen and press the menu button to save and exit
it could be a pixel setting so find pixel settings while the menu is on the scree and adjust to the correct pixel setting
there are plenty of remotes for tv units on e-bay
all you have to do is select one that is for sanyo led/lcd tv's and read the details to see it it works your model tv
Oct 01, 2016 | Sanyo Televison & Video
I have an older sharp tv. How do I adjust the brightness without the original remote?
You should be able to use the buttons on your TV to adjust settings. Using the menu channel and volume buttons to navigate the menus.
Nov 18, 2014 | Sharp Cameras
Why is my screen too white?
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 25, 2014 | Sanyo DP46848 LCD TV
How can i program my remote control to operate my TV?
You will need to get a programmable remote. The one you have will not work.
Jan 26, 2014 | Televison & Video
Cannot figure out where to adjust the brightness, color, so on
You have to enter its menu option to adjust all this. Get into its 'Menu', surf and come to picture settings. Here you can adjust all the parameters. If your TV has no 'Menu' button at its front panel, you should have a remote control to get into 'menu' option. For more, refer the user manual to your TV.
If you don't have its remote control, and wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 17, 2013 | Sharp 36R-S50 36" TV
Tv picture is too dark and looks like everyone wearing lipstick went to menu but it doesnt help tv just a yr old
You need to adjust the brightness, tint, contrast, and brightness in order to get the color to even out. Menu; settings; display. If you no longer have the remote, either buy a universal, or use the tv buttons(channel + - should navigate the cursor) to enter menu mode. Be patient because it can be frustrating; so don't do it when agitated, hungry, or tired. GL
Apr 05, 2012 | Sanyo Televison & Video
Too much bright
there are controls in remote by which we can decrease the brightness. u did not mentioned if they are working. try to decrease brightness by pressing the menu of remote & going to picture controls & find brightness control there.
if above function not controlling the brightness of tv, there may be fault in lcd panel of your tv. which may be diagnose only after seeing exact condition of picture.
Sep 03, 2011 | Samsung LN32A330 32 in. LCD TV
Vert hight adjustment
How do I adjust the vertical hight of a SANYO 36" TV. vertical height can adjusted by height conrol that is inside tv in your case you can also adjust by remote control. for that you will have to open menu by giving service code. regards thanks
Sep 10, 2007 | Sanyo AVM-3659S 36" TV
Sanyo DP32746 32 in. LCD Television Logo
1,109 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
