Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Ws 55513 blinking green light on front of tv. tried shutting off with remote, tried unplugging power,tried holding down remote power button,i left it blinking for 5 hours never turned on tried resetting still blinking green light....help...
  • 3 more comments
  • sbranum Jan 02, 2008
    blikning green light and TV will no power up, ho can i fix this myself and it the board behind the back panel on the left? can the parts be bought a Radio Shack?
  • Biggin69 Jan 08, 2008
    double blinking green light and TV will not turn on
  • kinhdo Jan 20, 2008
    My Mitsubishi WS-65613 front green light blinking forever and TV will not turn on no matter how many times i patiently try the power button, the reset pin... I tried to power off the TV for 10 mins then power it back on but no help. Please please help.
  • Anonymous Jan 26, 2008
    Same problem as others no matter what reset button will not reset! Unplugged unit tried everything the other people posted and still can't get it to reset. HELP!!!!!
  • tfizzle Oct 25, 2008
    i have this same problem, but on the WS-55513. can anyone hepl me?
Does anybody have a "how to fix this" for dummies. It appears this is a major problem in Mitsubishi projection sets. I have the WS-65613 and this has recently started. If anybody has a clue on repair,please provide anything. Randy
Posted on Sep 23, 2007
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Posted on Sep 22, 2007
SOURCE:
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Blinking green light on mitisubishi ws55813
error code. return to supplier. Possibly power supply
Dec 25, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
246 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
