Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
POLARIS ATV COOLING PROBLEM
I HAVE A 2002 SPORTSMAN 700 THAT IS OVERHEATING, THE FAN(TESTED TO BE GOOD) DOES NOT TURN ON, IS THERE SOME SORT OF SENSOR ON THE MOTOR OR RADIATOR THAT CALLS FOR THE FAN TO TURN ON, ANY SUGGESTIONS, THANKS DAVE
  • 1 more comment
  • K_tmanuel May 05, 2009
    I have an sportsman 700 with the same problem fan is tested to be good right now i have hard wired the fan to the battery with an on off switch and everything is great, but would like to fix the problem. Did replaceing the thermal sensor turn out to be the problem or was it a relay?
  • shagsl-72 May 11, 2009
    Where is the cheapest place to buy a fan motor?
  • bryan
    bryan Nov 10, 2016
    I have same problem replaced thermal sensor still fan will not come on ????????
There is a sensor on the lower right hand side of the radiator. It is about $75 to replace.
Posted on Apr 27, 2009
What is the easiest way to get to the battery on a 2008 polaris sportsman atv
Posted on Aug 24, 2010
Why the fan on 700 polaris sportsman 2003 wont start when hot
There is a temperature sensor on the radiator.If that doesn't work check wiring.
Oct 29, 2016 | Polaris ATV
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
Nov 29, 2015 | Polaris 2004 Sportsman 700 Twin
Why will the cooling fan on my 500 sportsman not turn on .?
I have a 2001 polaris sportsman 500 H.O. I have replaced the fan and the thermial fan switch,and checked the thermostat. Everything is either new or works there are no bubles in the coolant when its running I am running out of opptions . If I unplug the thermal fan switch and plug a jumper wire in the fan will run. I thought the new switch was bad and I tested it and it is good
Sep 13, 2014 | Polaris 2004 Sportsman 500 H.O
Overheating I have a 2005 sportsman 800. I'm having problems overheating. Raditor is clean,seems like fan does not come on in time.
Is the coolant level OK? Does the fan work at all. Check the fan activation sensor (thermister sensor). Down load, from Polaris, the parts manual (no charge).
Oct 13, 2009 | Polaris ATV
My 2004 polaris 700 sportsman atv keeps overheating
make sure you check the thermostat on the radiator, if it does not get signal that it is up to temperature, it will not send power to turn the fan on.
Sep 12, 2009 | Polaris ATV
Overheating polaris sportsman 700
you probly need a new heat sensor, its located on the bottom right of your rad, i had the same problem with my 700 the fan only worked when it was already over heating, i cut the wires flush at the sensor drilled a hole above the key switch and mounted a toggle switch, no more over heating,
May 26, 2009 | Polaris ATV
Cooling fan will not come on
I read somewhere someone had the same problem as you with the fan not kicking on. the guy took his to several dealers and finally got it fixed. he said it was the fan relay. so check the relay for the fan. if it has any mud or dirt in there then you'll get high resistance or even no connection causing your fan to not work and your engine to overheat. I hope that works for you, good luck! :D
May 18, 2009 | Polaris ATV
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
2,146 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
