Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
I have a 120gb portable hard drive.when ever i plug it in the comp shows a safely remove icon but no drive appears in the my comp. Also the light on the portable drive keeps flashing all the time
  • 39 Answers
The USB cable you're using is too long.
Posted on Apr 21, 2009
Wd 320gb driver
If the drive does not appear in Remove Device but does appear under computer you can right click on it then select EJECT.
Dec 03, 2013 | Western Digital Elements powered by WD 320...
My s2 portable is very sensitive, that when i donwloaded data on it, after a while, it will corrupt my data, and when i try this to connect to other pc, it not appear on MY COMPUTER, but when I reconnect...
Hi ajsallin ,
The problem could be resolved in the following ways :-
  1. Loss of data could occur as a result of directly removing your USB external hard drive without actually disabling it from your taskbar's bottom right corner , where you get an icon of devices connected , it's like a plug icon.
  2. You need to right click on the icon, choose the device that you want to remove and then disconnect it , till it says that you can now safely remove your hard drive.
  3. Once you have done this , try connecting your hard drive , to the USB slot of the different PC, than the one from which you copied the data on your hard drive.
  4. If the drive does not show up in my computer , it could be probably because you are using a USB hub or an extension cable to connect the hard disk.
  5. I would recommend you to remove any such cables or USB hubs and try connect the hard drive directly to your USB port via the cable supplied with the hard drive.
Hope this helps.
May 12, 2011 | Samsung S2 - 320GB USB 2.0 Portable -...
I attached the portable drive to my computer and i don't know what else to do
If a Windows based machine, locate and double click "My Computer" (or similar). A box will open and show the devices attached to your computer. Fixed drives such as "C:" appear under "hard disks and CD, DVD players, external drives and thumb drives will appear as "devices with removable storage" or as "portable storage"
Plug the drive's USB cable into the computer (if it isn't already) and double click the new drive to view the contents. Often times, these drives ship with software to perform back ups, or other utility - or include the manual and warranty information. You can use the drive as if it were one of the other permanently connected drives inside your computer.
Make sure that you click on the "Safely Remove Hardware" icon in the System Tray BEFORE unplugging the drive's USB cable. Data loss can result if disconnected before the data has been written completely to the disk.
I hope this helped & good luck!
Nov 01, 2010 | Seagate Computers & Internet
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
DataStation maxi m.u 250 gb
Does windows creates a drive letter for it?!
in "my computer" click "Manage"
and then "Manage disks"
does it shows up?!
If so, right click and assign a drive letter, try it now.
Sometimes, if you're using network drive letter assignments, windows messes up with upcoming pen drives or usb disks.
Sep 15, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
WESTERN DIGITAL
wiggle the cable connected to the drive gently up and down and side to side
I have the same problem with one of my drives, by doing the above it works. I think the connector inside "the conatcts" don't make good contact with the cable
thanks for rating
Jan 09, 2008 | Western Digital Passport WDXML800UE...
Maxtor password protection
I have seen this one before. You need to reinstall the Maxtor software and reset the encryption - if you do not have CD you can get the software online at:
http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Dec 12, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
278 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
