Express Appliance Repair Winnipeghttps://www.expressrepairwinnipeg.ca > general-electri...
If any wires are exposed or damaged then your temperature sensor is misreading your oven's heat which causes the F2 error code. If you have found any damaged or ...
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.5 · ‎950 reviews
Missing: 326B1230P001 ‎' Show results with: 326B1230P001
•Improper cartridge (Destination error, life cycle error) •Identific t ion error •Model error •Type error •Destination error •Data abnormality •Misc error Detail •The destination of the machine differs from that of the CRUM. •The trade mark code of the CRUM differs. •The company code of the CRUM differs. •The boot program model code does not coincide with the CRUM model code. •When the CRUM type is other than genuine/ conversion/production rotation. •The machine destination differs from the CRUM destination.
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
F2 with sub code 33 - grid voltage wrong, either too high or too low;
F2 with sub code 35 - grid voltage correction will not work during simulation;
F2 with sub code 37 - drum mark sensor adjustment required.
You may post further comments for more help or information......
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
