Question about Panasonic FP-7735 Black and White Copier
I have an FP 7735 Panasonic copier but I keep getting a blamk line running down the page. I just replaced the corona assy.
  • ksayles Apr 21, 2009
    • Is the charge corona different than the corona assembly I just installed? If so where is it located in relationship to the corona assemby?
  • ksayles May 04, 2009
    The charge corona looks clean, is there anything else that would put blank lines running verically down the copy?
  • 117 Answers
You need to clean the charge corona.An eraser will work.I use a folded piece of scotch brite pad held with a pair of hemostats.Be careful not to break the wire.Good Luck!
Posted on Apr 21, 2009
  • John Harris May 01, 2009
    The charge corona assembly is on top of the drum, at about the 12 O'clock position or thereabouts.The one on the bottom is the transfer and separation corona.Both should be fairly simple to remove and replace.Good Luck.
My Panasonic FP-7160copier is showing code: c0210. What does it mean?
C0210 indicates a problem with the Transfer/paper separator corona unit.( the one below the drum)..it is either dirty, not installed properly or may need replacement.
Nov 05, 2010 | Panasonic FP-7735 Black and White Copier
E3 11
E3-11 indicates a problem with the Transfer/Separation corona unit...the unit below the drum.
Either dirty, out of place, broken wire etc, etc.
Sep 25, 2010 | Panasonic FP-7735 Black and White Copier
Dark, streaked copies
I would first start by cleaning the optic's & cleaning the primary & transfer corona wires and do a general cleaning and that may solve your problem? Good Luck
Sep 10, 2010 | Panasonic FP-7735 Black and White Copier
I like to sell it itr wors good Panasonic FP-7735
please consult your local newspaper to advertise. this is an old copier with old technology .
Apr 18, 2010 | Panasonic FP-7735 Black and White Copier
Error E3-10
E3-10 is for the corona assembley. try to remove the corona assembly and then put the machine on and i think next you ma know what to do if u are a technician ,bye enjoy
Mar 16, 2009 | Panasonic FP-7735 Black and White Copier
FP-7735 prints gray pages.
needs developer tech installed because of the adjustments that have to b done afterwards7734748865
Feb 02, 2009 | Panasonic FP-7735 Black and White Copier
Drum for FP-7735 HELP?!
Would reccomend that you get a technician to do this as he will need to reset settings in the copier.
Dec 13, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 error E7-01
E701 is reported when the controller is unable to communicate with the IOT(image output terminal).The following check might save some further troubles.
1.If the the controller is pretag 2,connect a terminator to the SCSI port marked "HOST"
2.Disconnect the IOT,power up the controller,press the reset switch on the controller board and allow reset cycle to complete,power down,reconnect,insert floppy firmware,power up.
3.Down grade to firmware 2.7
4.Check PSU +5V and +12V at the pcb.
5.Check HD drive present on the config printout.
6.Check reset switch if not stuck in on controller.
7.Check controller to IOT cable in good condition.
8.Replaced the flash SIMMs
And lastly if all the above fail to cure the fault then replaced the controller board.
Jan 03, 2008 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 trouble shooting
That could be a few things. Your corona wires might need replacing. Something with the middle transport section, where one of the corona assemblies is at, is not making contact properly. Or it could be the high voltage power supply.
Nov 05, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic 7735 problem
did you tried to restart the copy machine or to disconnect it from electricity for few minutes?
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Black and White Copier Logo
94 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
