Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
I have whirlpool duet electric dryer and it drys it has a high pitch continous beep and even shutting off won;t help it has to be un plugged to stop.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed or has a stuck button in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Whirlpool Duet dryer is making a high pitched screeching noise. Model gew9250pw1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Whirlpool Dryers
My whirlpool duet electric dryer will turn on run for a minute than turn off and smells hot
Check the dryer vent,some times they will get stopped up with lint causing the dryer to shut off on high temperature.
Mar 03, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpools Duet GEW9200LW . . . heats up but never drys clothes completely
Assuming your lint filter and ductwork is clear of excess lint, the problem is likely the high temperature limit thermostat. This is cheap and easy to fix.
http://www.repairclinic.com/PartDetail/High-Limit-Thermostat/526282
Good luck.
Mar 01, 2011 | Whirlpool Dryers
Drum will not turn on dryer makes a high pitch shrill when you push the button
u are going to need to replace the dryer drum drive belt and inspect the rollers the drum ride in, here is how to replace the belt.
please follow the safe link to the how to site on your dryer.
http://www.instructables.com/id/How-To-Replace-a-Dryer-Belt-on-Whirlpool-Models/
Jul 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
WHY IS MY DRYER NOT DRYING ON NORMAL CYCLE?
whirlpool dry gew9200lw0 problems is contorl locked what the solution
Jul 06, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Dryer GEW9250P (electric)- how do i unlock dryer?
its a botton to the far right that says child lock,,,press and hold for 3 seconds,,if this doesnt work un plug it for a minute..than replug
Dec 19, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
