Question about Mitsubishi WT-42311 42" Rear Projection Television
Will not stay on
The TV all of a sudden one night just turned itself off .When you turn the power on it comes on for about 3 seconds then it turns itself off. We call Mitsubshi and told us to turn off for 20 min and turn on again but that didn't work. Did the bulb go out? Any suggestions?
  • 2 more comments
  • gentrytw Nov 01, 2007
    Please, someone help with this. I want my TV back. lol
  • gdc1964 Nov 15, 2007
    I am having the same issue. TV worked fine, then shut off and when I attempt to turn it on, the light comes on for about 3 seconds and shuts itself off. I tried pressing the menu and input buttons simultaneously but nothing changed. HELP!
  • redlay Nov 16, 2007
    tv 55in won't stay on, turn tv on and then it clicks off. what to do, what to do?
  • Anonymous Nov 27, 2007
    I was having the same issues and had a repair service come to my house. They had to replace the amps and things have worked since then.
    Problem Solver:
Do you have any sound? If not, open the panel and press the menu and input buttons and the same time, count to three and then there will be a code flashed,  it will flash a t least once followed by a pause and then a nother set of flashes let me know
Posted on Oct 11, 2007
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Feb 01, 2013 | Samsung LE Televison & Video
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Sep 01, 2012 | Philips 60PP9352 60" Rear Projection...
Last night the set just turned off by itself. When I try to power on, the power light comes on for a second and then it shuts itself off again.
I am having this exact problem. The TV turned off by itself and now when I try to turn it on, the power light stays on for a sec and goes of with a click sound.
Any TV experts who can HELP?
Apr 20, 2010 | Mitsubishi WT-46807 46" Rear Projection...
TV won't stay on
You will have to call an Authorized Panasonic Servicer. Any modules bought from them requires an authorization. Since your not a service center, it's going to be almost impossible for you to do anything. Play it safe and have it looked at.
Aug 20, 2009 | Panasonic TH-50PX75U Plasma HDTV
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Apr 21, 2009 | Toshiba CF36G40 36" TV
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
Turns off after a few seconds
The unit is going in to shutdown. There is a short in the unit. My guess would be the HOT and or Flyback are bad.
Jan 05, 2007 | Panasonic PT-47WX51 47" Rear Projection...
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Mitsubishi WT-42311 42" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
