Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
Dictionary language for text messages changed
The language for my t9 in messages seems to have changed from english. everything else in my phone is still english, but common english words no longer come up. it may have happened when i reset my samsung omnia, not sure.
  • Anonymous May 06, 2009
    This has happened to mine. I puy an O2 sim in and since then it has changed all the predictive text words to some foreign language and doesn't recognise any english words. Any ideas would be greatly appreciated.
  • Anonymous May 25, 2009
I was having a similar problem, if you go into a message and then press down the bottom where you would change the keyboard/input type (Samsung Keyboard, Samsung Phonepad ect.) > select Options....... >Input method tab > options > select English from the drop box > check that the XT9 Settings is also set to English. I hope this fixes the problem for other people with the same issue
Posted on Jun 12, 2009
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do I turn off predictive text?
While inside of a new message hit the top middle button and it woudl brign up a menu and in there change the dictionary to normal from english t9...
but you shoudl figure it out cause you can write a paragrah in liek 30 seconds with it
Mar 24, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Krzr won't stay on t9 text
open a new text message go to "options" select "Text Setup" and change the primary text: to iTap English instead of TAP English this will fix ir :]
Mar 07, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Hi i bought a phone which is N82 smart phone, however when i connected to my Tmobile network it is working properly but the only thing is that when someone sends me a text message it is in chinese. So, how...
Here's what your user guide says..
Press , and select Tools > Settings >
General > Personalization.
Language
Changing the settings for the phone language or
writing language affects every application in your
device, and the change remains effective until you
change these settings again.
Phone language — Change the language of the
display text in your device. This also affects the
format used for date and time and the separators
used, for example, in calculations. Automatic
selects the language according to the
information on your SIM card. After you change
the display text language, the device restarts.
Writing language — Change the writing
language. This affects the characters available
when writing text and the predictive text
dictionary used.
Predictive text — Set predictive text input on
or off for all editors in the device. The predictive
text dictionary is not available for all languages.
Good luck. Plz rate this if it helps you. Thank you kindly.
In case you didnt get the userguide I'll add a link for it also...
http://www.phonedog.com/cell-phone-research/nokia-n82_user-manual.aspx
Jan 31, 2009 | Cell Phones
Change text message language in Samsung SGH-U900
Try holding down the # key and a menu should pop up with the various typing styles. I changed mine to T9 abc and it works fine now
Nov 14, 2008 | Samsung U900 Soul Cellular Phone
Text message input
Try this:
Go to your phone MENU then into your Messaging ->Text and into the Create new/Compose new text...next is go to the Options/More and Deactivate or turn your T9 dictionary OFF....Or go to where your T9 dictionary is located....by doing this, you have prevented the shorthand popups to appear while typing messages...I hope I have provided you the right solution regarding this problem.if you have further questions,just post it here or you can ask me directly...Good luck!
A rate from you will be much appreciated...thanks.....
Oct 12, 2008 | AT&T Cell Phones
Changing language so i can text message
open a creat new tex message options and look for somethin like edit T9 dictionary, input language input type failing this come out of the thx message to messages and find settings and repeat above
Jun 17, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
The text dictionary keeps giving me the wrong words and i cant change, how do you knock it off. the phones a samsung d900i
Using T9 mode
T9 is a predictive text input mode that allows you to
key in any character using single keystrokes.
Entering a word in T9 mode
1. Press [2] to [9] to start entering a word. Press
each key once for each letter.
For example, press [4], [3], [5], [5], and [6] to
enter HELLO in T9 mode.
T9 predicts the word that you are typing, and it
may change with each key that you press.
2. Enter the whole word before editing or deleting
characters.
3. When the word displays correctly, go to step 4.
Otherwise, press [0] to display alternative word
choices for the keys that you have pressed.
For example, OF and ME use [6] and [3].
4. Press [ ] to insert a space and enter the next
word.
Other T9 mode operations
• Press [1] to enter periods or apostrophes
automatically.
• Press [ ] to change case. Lower case (No
indicator), Initial capital ( ), and Capital lock ( )
are available.
• Press [ ] to insert a space.
• Press the Navigation keys to move the cursor.
• Press [C] to delete characters one by one. Press
and hold [C] to clear the display.
Adding a new word to the T9 dictionary
This feature may not be available for some languages.
1. Enter the word that you want to add.
2. Press [0] to display alternative words for your key
presses. When there are no more alternative
words, Spell displays on the bottom line.
3. Press <Spell>.
4. Enter the word you want using ABC mode and
press <OK>.
"The faulty interface lies between the chair and the keyboard"
Apr 21, 2008 | Sony Ericsson w580i Cellular Phone
Unable to turn off t9 dictionary
try to hold the # button, or press it a few times durring the text message - it should flip from t9 to standard and maybe even symobls.
or else go into your message, being a new message then go to options - you should see some option change from t9 etc.
Dec 23, 2007 | Samsung SGH-D600 Cellular Phone
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
574 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
