Question about Refrigerators
Cannot get ice out the door
I have a whirlpool gold conquest the green light is on for cubed ice but no ice will come out door the same for crushed ice it is not stoped up ihave empted holding tray the lock out is turned off cannot hear motor runing
  • davidearlf Apr 23, 2009
    i checked the wiring at the top of door everthing looked ok but thanks anyway
  • 700 Answers
Check to see if theres a bad connection where the wires come from the freezer door and the frig itself under the upper hing cover
Posted on Apr 21, 2009
MY ICEMAKER IS STUCK IN THE CRUSHED ICE CYCLE WONT PUT OUT THE CUBED ?? EVEN WHEN I PUSH THE BUTTON BACK AND FORTH WONT SWITCH ??
if you have selected cubed on the door and still wont dispense cubed ice likely cause is the cubed ice solinoid( located behind the panel in where the auger motor is located) thats the motor that turns the curly thing in the ice cube resivoir.....!!!
Jun 08, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Crushed ice does not work but cubed ice works as well as water.
pull down and turn the pole that fits over the bar. This should work. If it is not changing by itself, then the solenoid will have to be replaced
Jul 09, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
FRSS36AF25/3 with exactly the same problem
ok it sounds like the motor or it may have spun the gear... if you go here www.techray1.com and click on the guru guy. it will take you directly to repair clinic where you can ID the part needed.
Since you have the ability to tear it apart. replacing the part will be easy..... let me know if this helps
Jun 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Cannot get ice out through the door
i have not fixed it yet i expected to get help here guess i was expecting too much
Apr 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6SHAXMB00 ice dispenser not working
remove the ice bin close door and push for ice and hear if the motor working if motor not could be door switch if motor working is the solideo valve
Mar 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice dispenser won't dispense whole ice cubes, only crushed
I found a temporary solution, I moved the bar so that the sliding door stays open and
stuck a piece of cardboard in it so it stays in the open position. I still need to get the
right tools to take the screws off on the side of the back panel because there is not
much room.
Jan 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
