How to replace fuel pump.
I need to replace fuel filter in 1998 caviler 2.2 engine
  • 23 Answers
The fuel filter is mounted to the rear cross member. Lay under the rear and you will see it. Its attaches with quick connects. If you break them removing them (you shouldn't), a new quick connect rebuild line is at autozone for 16 bucks
Posted on Apr 21, 2009
I need a tool list for replacing a 2002 caviler fuel pump and filter.
Okay Tanner,here's a guide to get the job done.Here's how to relieve fuel pressure.Here's how to replace your fuel filter Tanner.Here's your fuel filter Tanner.Here's the fuel pump,high dollar part.
Jan 31, 2013 | Cars & Trucks
I had this issue for my 1998 town and chryler lx1 that when I started the engine it did start but for a 2 to 3 seconds and then came off
From your description it appears to be starving for fuel. You need to make sure the fuel pump is running. Listen at the fuel filler door, cap off, while someone else turns on the ignition without starting the engine. If you do not hear the pump run check the fuse, and fuel pump relay. Even if you hear it run that does not mean it is pumping with enough pressure. If you have never replaced the fuel pump on this 13 year old vehicle I would suspect it is bad. Also replace the fuel filter is you have not in the last 50,000 miles.
Sep 15, 2011 | 1998 Chrysler Town & Country
Stalls when coming to a stop
Mine stalled when I stopped and it was the Idle Speed Motor. If it only stalls when you stop, I would check that before messing with the fuel filter or pump.
Aug 23, 2010 | 1998 Ford Taurus
Engine will not crank unless you manually pour gas directly !
If car cranks his way but does not start 1 check your fuel filters for blockage. 2 check fuel lines make sure they are clear. If still not starting 3 replace fuel pump
Jul 11, 2009 | 1998 Chevrolet Malibu
I need to replace the fuel pump on a 1998 chevy caviler 2.2 engine.
The fuel pump is in the fuel tank you have to remove the fuel tank and there will be a retaining ring that holds the pump in losen the retaining ring and take the pump out of the tank be carefull not to bend the float wile removing the pump or your gas gauge wil not read. then just put in new pump and putt it all back together it should only be a bout and hour to and hour and ahalf job for you
please rate me
thank you
Apr 21, 2009 | 1998 Chevrolet Cavalier
Fuel Filter Clogged? - 1998 Toyota Avalon
this year car have 2 filters: one inside fuel tank that generally not to change until not change fuel pump, and other external at engine room that changes aprox every 20k miles
Apr 05, 2009 | 1998 Toyota Avalon
'99 chevy caviler fires right up, but then dies after started, like out of gas. Fuel relay sensor? fuel filter? fuel pump?
If it is fuel injected it will get enough fuel to start but not stay running. I had the same problem with my S10. Turns out the hose that went on to the end of the fuel pump was roted. pull the sending unit and check the hose connections to the pump and the sending unit. If problem presists replace filter first the pump.
Jan 25, 2009 | 1999 Chevrolet Cavalier
Replacing a fuel fitler
In my regal gs 1998, the fuel pump is n fuel tank. There is a resister that I replaced to fix stalling and shutting down of engine.
Dec 06, 2008 | 1998 Buick Regal
Replaced fuel filter, now won't start
a cut off switch is almost never the problem just hummor me for a second and please check that the fuel filter is installed correctly not backwards then check the fuel pump fuse and relay if all good check for power at the pump and a good ground if all this is good then the pump need replacement
Oct 18, 2008 | 1998 Kia Sephia
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
