Question about LG Cell Phones
Changing ringtone The inside screen on my phone is broken. I want to change the ringtone. The person who gave me the phone no longer has the owners manual. I need someone with a similar phone to guide me through the process. I want to change the downloaded ring to a pre-programmed low ring with vibrate.
K, to change the ringtone u go into menu. press the ok button then u press; 8, 4, the top nleft button, then u press the down button once, then the ok button and then your done
Posted on Feb 01, 2008
    Problem Solver:
  • 5 Answers
I'll try to help you with this, but I need to know which profile your phone is currently set on. Mine is on "General", so once you find out, I'll guide you through it. My email's [email protected]
Posted on Oct 03, 2007
SOURCE:
Set my fav tunes as ringtone ?
Ringtones or songs downloaded or copied to your storage card are not automatically added to the ringtone selection menu. You need to go to the Music application and set a ringtone or song in your storage card as your ringtone. To do that top up arrow and Music then tap the three paralel lines at the bottom-left corner of the screen to go to the Library. Play the song that you want to use as a ringtone and on the Playback screen, press MENU and then tap Set as ringtone.
To change the ringtone press MENU, and then tap Settings. Tap Personalize > Default ringtone. The Phone ringtone selection menu then opens and you can scroll through the available ringtones and tap the ringtone you want to use then tap OK.
Feb 14, 2011 | HTC Wildfire Cell Phone
I have not an icon to personolise mij htc desire so i cannot change my ringtone for calling or sms How become i that
To change the ringtone press MENU, and then tap Settings. Tap Personalize > Default ringtone. The Phone ringtone selection menu then opens and you can scroll through the available ringtones and tap the ringtone you want to use then tap OK. Ringtones or songs downloaded or copied to your storage card are not automatically added to the ringtone selection menu. You need to go to the Music application and set a ringtone or song in your storage card as your ringtone. To do that top up arrow and Music then tap the three paralel lines at the bottom-left corner of the screen to go to the Library. Play the song that you want to use as a ringtone and on the Playback screen, press MENU and then tap Set as ringtone.
Feb 01, 2011 | HTC Desire Cell Phone
How do I assign a ringtone to a person when the ringtone is sitting in my message inbox?
click on the message inbox ,then go the ringtones then stroll down o sound .selected ringtones you want,then it will gave you a option to set a ringtone for this person ..click on set as ringtones and that will allow you ringtones you assign for the person
May 20, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Changing ringtones and alerts on sony satio
I believe that you go into settings/personal/profiles. There you can highlight an existing profile or create a new profile. When you highlight a profile you can select option button, then tap personalise and this with give you options to change ringtones, ring type, message alerts etc. Hope this helps
Nov 02, 2009 | Sony Ericsson Satio Cell Phone
Ringtone instruction
you can easily change the ringtone. Follow these steps:
1. In Idle mode, press <Menu>--> Settings --> Phone Settings --> Phone Profiles.
2. Scroll to a profile.
3 Press <Options>--> Edit -->Voice call ringtone.
4. Select a ringtone category --> a ringtone.
5. Press <Options> --> Save profile.
Now you are done changing you ringtone. Try it!!!
Sep 15, 2009 | Samsung J700 Cellular Phone
Ringtone
it should be as simple a going into profile select customize then edit pick the song you want and save,,,,,,but hope your changing your voice ringtone,, and not the one that say video ringtone there are right below each other if your changing a ringtone for a specific person ofcourse you must be in contacts,, edit,,, then scroll down and change the default ringtone and save,,,hope it helps.
Jul 29, 2009 | LG KU990 Viewty
Change ring tone
Here's how to choose your phone's tones, alerts, vibration etc: 1. On the main standby screen, press the white menu button.
2. Select "Settings".
3. Select "Personal".
4. Select "Profiles".
5. Double-click on the profile you normally use (this will usually be "General").
6. Select "Personalise".
7. Click on whatever you want to alter (for example "Ringing Tone" to change the call ringtone). Note that there are different ringtones for ordinary and video calls, and different settings for keypads and touchscreens.
8. When you've finished altering the settings, press the red button to go back to the main standby screen.
To switch to a different profile, tap the standby screen's date and choose the profile you want.
How to choose a ringtone from the music player You can also select a ringtone from the 5800's music player, just go to the track you want to use and select "Options". One of the options will be "Use Tone", giving you the choice of using it as the ringtone for the current profile, or as the tone for a specific person.
Jun 24, 2009 | Nokia 5800 XpressMusic Smartphone
Bold 9000 ring and alert volume way too low, regardless of settings
Some of the ringtones in the Bold don't seem to be suited for "loud" profiles.
Try to edit your settings for the ringtone, making sure you pay attention to the correct settings.
To edit your ring settings
-go to your "profiles" screen -roll the ball to the bottom and select "advanced" -highlight the profile you want to edit -use your BB button to select "edit"
-choose the "phone" application -choose the setting you would like to edit (in holster or out of holster) -choose your volume setting from here.
This should solve your problem
Apr 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Ringtones for caller id
To assign ringtones, you need to make sure the entries are stored to the phone, and not to the SIM card. To check where it's stored, go to the phone book, select the name of the person you want to personalize (ring tone, picture, etc), and click edit. In the Entry Details screen, the Store to: option probably says SIM. Change it to Store to: Phone. After you do that, there should be alot more info you can put in for the person. Near the bottom is "Ringer ID" and "Picture" which you can then customize for the person.
Hope that helps!
Apr 25, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Cell Phones Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
